Re: Bent idler (pending solution) PIC
[Re: JohnnyBfromPeoria]
#972121
11/17/09 04:36 AM
I'm with Toasty on the "using Auto Zone parts that fail anyway" thing. At least you only have to pay for the part once. If they're dumb enough to lifetime warranty a part like that, I'm dumb enough to buy it. That's a good point, especially since they are the same price as OEM
[Re: Mad_Scientist]
#972122
11/17/09 04:41 AM
I like the bracket idea, if you can make it work, Toast.
John B. Oh by the way I work for Autozone now. Or I will be on 11-23. Not in retail.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Tag]
#972123
11/17/09 07:54 AM
I worked for them for 2 years and i suggested they make the idlers stronger for monteros or they're wasting their money. 100 Idlers later between all of us down here and they still suck.
Ok so I plan on picking up a spare Gen 2 idler to make a fixture out of it for making the support mounts, same goes for the gen 1 idlers. I'm hoping this will be as simple as i'm thinking it will be.
[Re: TOASTY]
#972124
11/17/09 12:37 PM
I would consider removing the nut and replacing it with a machined extension that threads on so the bearing you add is further down giving it more leverage to keep thing straight.
[Re: OldColt]
#972125
11/17/09 01:22 PM
I would consider removing the nut and replacing it with a machined extension that threads on so the bearing you add is further down giving it more leverage to keep thing straight. That's a good idea <img src="/forums/images/graemlins/kewl.gif" alt="" /> It's also worth mentioning again that the zombiezone idler arm as a longer shaft compared to the OEM. On the OEM unit there are not enough threads for this brace idea to work, making Charlie's suggestion all the more important <img src="/forums/images/graemlins/cheers.gif" alt="" />
