Engine/body vibrations after mudding #972184 11/16/09 09:48 AM
Szia Offline OP
I went to Azusa Canyon today for some mudding. I did some river-crossing/ driving up and down the river, mudding, and rock climbing. It was a tough day for the old beater and daily commuter, but it runs just fine like we are used to.
Here's the problem: When cranking the engine, there is vibrations coming from what seems to be the engine bay. However, the engine runs just fine when popping the hood, with all fluids topped out as they should. The vibrations are only noted in the car, and increase when revving the engine. On the highway, this low-pitched vibration/howl increases as speed increases. It isn't the tranny as far as I know, because it is there even when standing still and no gear is engaged.
Has anyone else experienced this? Any suggestions? I'm thinking it could be the rubber things the engine sits on to dampen vibrations, but I am not sure as I don't know where to look for them.
Any help would be appreciated! <img src="/forums/images/graemlins/scared.gif" alt="" />
Karl
1989 Mitsubishi Montero 2.6, 2 dr, 5spd.
Like Adventures? http://www.adventurehowto.com
Re: Engine/body vibrations after mudding [Re: Szia] #972185 11/16/09 10:56 AM
4ePikanini Offline
possibly a balancing weight on the propshaft that came off.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: Engine/body vibrations after mudding [Re: Szia] #972186 11/16/09 10:58 AM
StockRaider Offline
Check the condition of your motor mounts. I pulled my cross member twice before noticing the separation on the drivers side mount.
I checked mine by grabbing the engine by the intake (leaning over the fender for leverage) and rocked the engine back and forth.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Engine/body vibrations after mudding [Re: 4ePikanini] #972187 11/16/09 11:14 AM
Szia Offline OP
Thanks for the replies guys!
Where can I find the balancing weights (or the place where they used to sit) on the propshaft? Can these be replaced without replacing the propshaft?
I will definitely try this.
Could there have been damage to the harmonic balancer by any chance? I am not familiar with what it does, but saw that it is related to eliminating vibrations at specific frequencies of the engine and components. I don't see how that would have gotten damaged though, but I guess it is worth to ask. <img src="/forums/images/graemlins/confused.gif" alt="" />
Karl
Re: Engine/body vibrations after mudding [Re: Szia] #972188 11/16/09 05:40 PM
motero Offline
Mud in the harmonic balancer?
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Engine/body vibrations after mudding [Re: motero] #972189 11/16/09 06:30 PM
Could also be that a small amount of water made its way into a spark plug wire or under the distributor cap. That will make it run rough. Pop the cap off and dry it out first. Cost = one paper towel.
Re: Engine/body vibrations after mudding [Re: JohnnyBfromPeoria] #972190 11/16/09 06:32 PM
My bet's on one or more of the the plug wires or the distributor connections being wet.
Re: Engine/body vibrations after mudding [Re: off-roader] #972191 11/17/09 01:47 AM
Szia Offline OP
How can I clean out mud in the harmonic balancer? Is it possible to wash it out or is that covered behind the crank pulley and a gasket?
I will have a look at all connections and post back my findings.
Karl
Re: Engine/body vibrations after mudding [Re: Szia] #972192 11/17/09 05:09 AM
That's what I'd do.... plug wires on both ends (plug and distributor cap).
Re: Engine/body vibrations after mudding [Re: 4ePikanini] #972193 11/17/09 05:14 AM
Grasscat Offline
I don't think so as he said.
Michael j
TreadLightly! Trainer
PHP: 7.4.33 Page Time: 3.836s Queries: 15 (0.004s) Memory: 0.6412 MB (Peak: 0.7468 MB) Data Comp: Off Server Time: 2026-06-23 00:48:50 UTC
