Page 2 of 8 1 2 3 4 5 6 7 8
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972232 11/16/09 10:01 PM
LandRaider Offline
Ahhh.. you're planning on swapping the entire rear end. I was thinking you wanted to put that center section into your axle housing.
Entire diff swap is 100% a go.
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972233 11/17/09 12:08 AM
The SR front gears are high pinion, no go into your housing since it is a low pinion. The ratio is close enough that a few thousand miles of tire wear is a bigger issue.
Re: '95 SR 3.5 w/Air Locker [Re: OldColt] #972234 11/17/09 01:35 AM
FrankR Offline OP
Thanks, guys -
I knew this would happen soon after I installed the LSD from the Gen1 LWB.... and it hasn't even turned one revolution yet. <img src="/forums/images/graemlins/lol.gif" alt="" /> But that's a benefit of running a yard like this.... the stuff just comes to me if I'm patient. I guess I'll pull this SR axle with the parts Michael listed and save it for another day when I run out of projects. That sure is a beefy looking axle and it would be nice to have those rear discs. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
With some fresh paint, the 5 SR wheels will make nice street wheels for the G-Raider or the MM. <img src="/forums/images/graemlins/kewl.gif" alt="" />
More questions:
1) Is the flange face on the pinion the same distance from the axle center as the Gen1 so I won't need to shorten the rear propshaft?
2) Do I need the brake proportioning valve from the SR?
3) Aren't the SR front brake calipers dual piston type?
4) Will the SR front brake calipers mount on the Gen1 V6 knuckle?
5) Is the Gen V6 brake booster and brake M/C up to the task of the SR F/R brakes?
6) Are the SR front brake rotors the same size as the Gen1?
7) Can someone explain the benefit of the SR UCAs?
8) WMS-WMS = 2" more than the Gen1 axle? Looks like wheels with 1" more backspace and front spacers would fix that.
Frank
Re: '95 SR 3.5 w/Air Locker [Re: OldColt] #972235 11/17/09 01:37 AM
sewerrat Offline
IIRC, more gen II upgrades for the gen I are the front brake calipers (rotors too?), the idler arm, and steering box.
Edit: oops, I'm slow. <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972236 11/17/09 01:53 AM
The SR calipers and discs are wider than the gen1. The 3.0 Monteros and all the 90's Sports have direct swappable calipers with the same width discs. These use the same AP530 pads as 3000GTs, G VR4s Diamantes and other Mitsus so it is easy to get many compounds of brake pads.
I just swapped Sport calipers onto my MM and eliminated the rear axle valve. Only test driven at this point but I think I like it.
Re: '95 SR 3.5 w/Air Locker [Re: OldColt] #972237 11/17/09 04:28 AM
Mad_Scientist Offline
The only thing specific to SR is the locker. Otherwise any other parts of interest are the same on all 3.5L Gen2, or any Gen2 I suppose.
Yes, the front calipers are dual piston <img src="/forums/images/graemlins/kewl.gif" alt="" />
I believe the Gen2 UCAs are longer and so they help to set the camber on Gen1 trucks with cranked t-bars and the ball joint is beefier (?) <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: '95 SR 3.5 w/Air Locker [Re: Mad_Scientist] #972238 11/17/09 04:51 AM
FrankR Offline OP
The camber correction is what I can see would be helpful to some, but I have my front end set where I like it..... at zero camber.... with good ride quality...... and still have shims to toss if I need more UCA length to maintain zero camber. I don't plan to use a taller than a 32" tire, so I guess I don't need the UCAs.
Has anyone managed to use the dual piston front calipers on a Gen1?
Frank
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972239 11/17/09 04:55 AM
Grasscat Offline
More questions:
[color:"red"] It's a bolt up, no prop-shaft adjustment needed. [/color]
[color:"red"] No. [/color]
[color:"red"] Yes. [/color]
[color:"red"] Yes, backing plate needs some adjustments. Get the backing plates from the SR plus the little hard brake lines and their brackets. [/color]
[color:"red"] Yes, I even think they are the same part number. [/color]
[color:"red"] No, they are a little bit smaller in diameter, I think, but the Gen I's will work just find.
[/color]
[color:"red"] I see no benefit unless you crank you bar way up. Other may have more information. [/color]
[color:"red"] You lost me here Frank, (WMS) but the Gen II axle is about 3" wider than the Gen I [/color]
Frank
Here's my write up on the brake swap. You will not have to some of what I did as you have the Gen II parts.
Michael j
TreadLightly! Trainer
Re: '95 SR 3.5 w/Air Locker [Re: Grasscat] #972240 11/17/09 05:18 AM
WMS = wheel mounting surface
My Gen2 big axle is about 60"
Re: '95 SR 3.5 w/Air Locker [Re: Grasscat] #972241 11/17/09 05:25 AM
FrankR Offline OP
Thanks, Michael - that clears up the muddy areas nicely. <img src="/forums/images/graemlins/kewl.gif" alt="" />
What I meant by the wider axle width is that it should be possible to use wheels with more backspace to get the rear tires (C/L-to-C/L) track width back to approximately where they would be with the Gen1 axle. To avoid using different back-spaced wheels in the front compared to the rear, you could use the same backspace in front and rear if you used wheel spacers in front.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6529 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-07-13 04:53:45 UTC
