Page 1 of 8 1 2 3 4 5 6 7 8
'95 SR 3.5 w/Air Locker #972222 11/16/09 08:27 PM
FrankR Offline OP
We just had a '95 SR 3.5L come in. It has the air locker with 4.636 gears. The air pump is there under the passenger side of the rear seat.
Some questions:
1) Is this the locker that works on the Gen1 SWB 3.0L?
2) Has anybody had issues with the gear difference?
3) Can the SR front gears be swapped into the Gen1 3.0L front?
4) I took a quick look, but didn't see a locker switch.... where is it?
5) What other goodies do I want from this critter? Drive shaft?
Frank
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972223 11/16/09 08:32 PM
Frank
1) Yes
2) Not that I've heard.
3) Yes but 4.9's from a late model sport are a far better swap
4) Switch is on left side of bottom of center dash under radio area.
5) Can't think of them off hand but someone else will chime in. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972224 11/16/09 08:37 PM
LandRaider Offline
i don't think so since it is behind a 3.5
My gear difference between 4.636, and 4.56 doesnt matter, so neither should that.
I dont think so.
Yep on the console near the shifter.
to put a 350 in it.
Frank [/quote] <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: '95 SR 3.5 w/Air Locker [Re: LandRaider] #972225 11/16/09 08:55 PM
FrankR Offline OP
3.5 looks like 350 if you move the decimal.
Frank
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972226 11/16/09 09:15 PM
you can swap over the whole IFS from that truck as an upgrade and swap the whole rear. Keep the front 8" diff from the gen 1 though that way you won't have the center axle dissconnect plus it'll be less work.
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972227 11/16/09 09:16 PM
Mad_Scientist Offline
1) I think they all will so you may as well have the 9.5" diff this one has. The only issue might be the drive shaft U-joint but that seems to be potluck
2) You don't have 4.6 gears in the front already?
3) Nope, 3.5L Gen2 diffs are bigger. Some have talked about a full diff swap but I'm pretty sure it's not a bolt up
4) Next to the cigar lighter forward of the shifter (R/D lock)
5) Drive shaft if your Gen 1 U-joint is different. Front brakes, upper control arms, trailing arms, although you'll get those with the axle I'm sure. I' think that's it.
Re: '95 SR 3.5 w/Air Locker [Re: LandRaider] #972228 11/16/09 09:29 PM
Sure it will if you swap the entire axle which I assume (I know... I know) is what is being referred to here and not just the rear diff which def won't fit properly in a Gen I rear diff housing)
I dont think so.
Wait... I thought the gear size (8" IIRC?) is the same & this is one reason the ARB 110 fits in both a Gen I v6 and a Gen II 3.5L SR?
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972229 11/16/09 09:32 PM
Grasscat Offline
Some questions:
Frank
Frank,
I have made this swap into my Gen I. Here's what you need.
Short version;
Rear axle, drive shaft flange and bolts that bolts to the third member, the four doughnuts and compressor with it's components.
Long version;
The whole rear end including the drive shaft flange that bolts up to the third member and the bolts. No need to get any of the ABS stuff or the sensor cable for the locker CPU. Leave the panhard rod on the axle, less dis-assembly that way.
The compressor under the rear seat including the metal panel it is mounted on, get the connector along with some of the cable that mates to the compressor. Get the air hose or you can add new. You don't need the locker switch as it's the momentary type. I used a aux light switch for mine.
The 4.636 gears should be the same as your Gen I, so you don't need anything from the front end.
Get everything ready for the install as I know you will.
To install, change the drive flange (brain failure here can't remember the name of the flange) from the SR to the Gen I drive shaft using Mitsubishi universal joints.
Remove the Gen I rear and replace with the SR, using your springs if you are happy with them. Everything bolts up the same except use the rubber doughnuts from the Gen I for the trailing arms, 1/2 may work, you'll see. Hook up the break line. Cross the brake cables and reroute. Run +12 volts to the compressor from your new switch you have installed somewhere. Bleed the brakes.
That's it, you'll have a locker anytime you flip the switch. Drive around a corner to see if it makes a differences. <img src="/forums/images/graemlins/lol.gif" alt="" />
Next up get some fender flares from JCW like I did. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: '95 SR 3.5 w/Air Locker [Re: off-roader] #972230 11/16/09 09:33 PM
Oyaji_Jon Offline
If I'm not mistaken, Frank already has the Aussie Locker in his front diff...
Frank, I'd just leave the front alone with the exception of the Upper Control Arms. Swap those to your Gen I and call it good. My 2 pennies...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: '95 SR 3.5 w/Air Locker [Re: Oyaji_Jon] #972231 11/16/09 09:57 PM
FrankR Offline OP
Thanks, fellas - I'm up to my ears today and not enough time to digest all this, but I'll take another look at the suggestions tonight and sort it out.
I did find out why I don't see the switch...... it's gone, along with the lower panel above the console.
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6517 MB (Peak: 0.7808 MB) Data Comp: Off Server Time: 2026-07-13 04:51:27 UTC
