Page 3 of 8 1 2 3 4 5 6 7 8
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972242 11/17/09 05:41 AM
Oyaji_Jon Offline
Just a reference point to throw out there...
I am running 33x12.50x15 tires on my Raider and have cranked my t-bars to the point where I needed to trim my bump stops. After I did my "lift", I had no problem getting the rig aligned to 0 camber.
Frank, it looks like you've got some work to do, buddy! And to think that that rig just landed in your lap! <img src="/forums/images/graemlins/kewl.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: '95 SR 3.5 w/Air Locker [Re: Oyaji_Jon] #972243 11/17/09 06:13 AM
GreatWhiteShark Offline
I put a 95 rear end in my rig and ever since then it feels like i am " lugging " in every gear.
and my transfer case grinds when i hit a bump hard enough.
Re: '95 SR 3.5 w/Air Locker [Re: off-roader] #972244 11/17/09 06:21 AM
Bagpiper Offline
how are the heads ?????? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
95 Montero SR/NANKANA 31 10.50 AT/Bouncy seat/Cobra CB/K&N air cleaner/Hi-lift Jack/Jerry Can/ tweaked torsion bars/Timing belt assembly/ Rage roof rack/ triple gauge system /Superwench hubs/2.5" lift/
92 Nissan Pathfinder XE (the Wife's)
Re: '95 SR 3.5 w/Air Locker [Re: Bagpiper] #972245 11/17/09 06:59 AM
87Montero Offline
Frank, let me know if you need some hand wrenching, a co worker and I can use some parts for our trucks. smile
Re: '95 SR 3.5 w/Air Locker [Re: GreatWhiteShark] #972246 11/17/09 08:06 AM
Sounds like your install was botched, you might want to go through it again.
Re: '95 SR 3.5 w/Air Locker [Re: TOASTY] #972247 11/17/09 05:20 PM
justice Offline
Frank, I recommend you read my thread on the swap as I swapped in a 96 axle into my 89 SWB. This will answer most of your questions and there are some decent photos.
Also, if you can find my 89 build thread it has a brief description of the front brake caliper swap. title is "New addition to family 89 SWB" or something to that effect.
I would just post up some links for you but the internet is way too slow here for me to figure it out right now. Maybe if you search my user name?
Don't forget to swap out trailing arms. The Gen 2 arms are the same dimensions on all mounting points, but are thicker in the weak spot and do not snap like the gen 1 arms have been known to do on occasion.
Re: '95 SR 3.5 w/Air Locker [Re: justice] #972248 11/17/09 06:00 PM
FrankR Offline OP
Justice, thanks..... I'll do that. I need to use the search function! <img src="/forums/images/graemlins/lol.gif" alt="" />
I just looked at some 2000 Sport calipers that are in excellent condition with nice backing plates - that seems to be the best path unless the SR rotors and knuckle will fit on the Gen1 - not likely if the upper ball joint is larger on the SR - or unless the SR rotor will fit the Gen1 knuckle. In any event, the Sport calipers should be an improvement over the single piston Gen1.
I hope all's well where you are.
Frank
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972249 11/17/09 06:15 PM
justice Offline
rear end swap
Frank, try that.
As far as the brakes go. You can go two routes. Simply swap on the gen2 calipers along with the gen 2 mounting brackets. They are a direct swap to the gen 1 knuckles. Dont forget to swap ( or modify the gen 1) the dust shields. Retain the gen 1 Rotors if you want.
Or..DO the same as stated above, but swap the calipers over as well. They will swap over as well. Diameter is the same but the gen ii's are a bit thicker.
No need to swap the knuckles.
The thing I like about the en 2 arms is that the ball joint is a bolt on unit vice the press through fit thats on the gen 1 arms. I dont think they are any more "heavy duty than the gen 1's just different. Another thing I like about them is that the cross shafts are isolated by rubber bushings which transfer less road vibes to the frame. some report a smoother feel with these..I have a set standing by at home in the garage for my 89 but havent tried them yet..
Re: '95 SR 3.5 w/Air Locker [Re: justice] #972250 11/17/09 07:04 PM
FrankR Offline OP
Thanks - I just finished reading the complete thread and went to look at the SR's manufacture date. It's June '94, so that one will need some driveline work to mate to the Gen1 shaft.
Maybe I'm being short-sighted, but I think I'll pass on it and wait to see if a later manufacture date shows up, since I'm not ready to bolt it in right now. All it would do is sit around and probably get damaged.
Thanks to all for doing the spade work on this swap. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
Re: '95 SR 3.5 w/Air Locker [Re: TOASTY] #972251 11/17/09 09:59 PM
0778drz110 Offline
<img src="/forums/images/graemlins/cyclops.gif" alt="" /> That not right dude, are you sure they were 4.636?
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6479 MB (Peak: 0.7576 MB) Data Comp: Off Server Time: 2026-07-13 06:10:54 UTC
