Page 5 of 8 1 2 3 4 5 6 7 8
Re: '95 SR 3.5 w/Air Locker [Re: justice] #972262 11/19/09 08:06 PM
Caps shows 93- mid 96 a different number. With a tape rule both my 95 SR and my 94 MM are the same. But I do agree the PN are different, I thought they superseded to the same part last time I looked. Looks like I should measure a bit better eh.
Re: '95 SR 3.5 w/Air Locker [Re: OldColt] #972263 11/19/09 10:42 PM
StockRaider Offline
I took my 89 and 95 drive shaft to my local machine shop. $69 total to cut weld and balance. Very strong and worth every single penny.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: '95 SR 3.5 w/Air Locker [Re: StockRaider] #972264 11/20/09 01:01 AM
FrankR Offline OP
I still might get the axle and change the yoke on my propshaft.... there's just a lot of other stuff going on right now, and the u-joint/yoke issue, while not a killer, is another time sink that means I'll have to store the axle until I can get the time to do it. With the engine build going on, stuff at work getting busy, holidays around the corner and with folks coming from CA for a big upcoming football game, time is a luxury. Today, just as I was about to install the heads on the engine, my next door neighbor showed up for a look at the engine....... there went the rest of the afternoon. <img src="/forums/images/graemlins/baby.gif" alt="" />
I still think it's better to use the later axle if one is available.... it would be easier to remember what u-joint to use when needed and less trouble to do the swap. That said, it also makes sense to grab what's available when it is - particularly at the price.
Frank
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972265 11/20/09 01:05 AM
StockRaider Offline
I wish I was closer by, its about a 4 hour job if your taking your time. Me and Brendan would have that thing SR swapped front and back in a day. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1983 Honda XL600R
Re: '95 SR 3.5 w/Air Locker [Re: justice] #972266 11/20/09 02:57 AM
Grasscat Offline
Frank, If you have the time you should snag the steering box out of that 95 also..Its a little more heavy duty than the 89 unit. It has a thicker shaft, so you need to retain the 95 pitman arm. Kevin C did this one. Its another one of those parts I have in the garage waiting to go in my 89. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Make sure you get the hard lines also because the fittings on the ends are different on your SWB truck.
Michael j
TreadLightly! Trainer
Re: '95 SR 3.5 w/Air Locker [Re: Grasscat] #972267 11/20/09 05:43 AM
GreatWhiteShark Offline
and do not forget the emergency brake cable. you need the one from the newer unit!
Re: '95 SR 3.5 w/Air Locker [Re: GreatWhiteShark] #972268 11/20/09 02:40 PM
hazy_daze Offline
Frank, get the axle. You won't regret it, I promise. If you need me to come take it out for you, I can work it into my holiday schedule. I've also got an excellent driveshaft man here in Athens. I can take care of the details, if needed.
Re: '95 SR 3.5 w/Air Locker [Re: hazy_daze] #972269 11/20/09 07:03 PM
FrankR Offline OP
Thanks, Larry - I've got a covey of yard birds here that can pull it for me...... after I get through with the lecture on being careful and not damaging anything <img src="/forums/images/graemlins/lol.gif" alt="" />
Frank
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972270 11/20/09 10:35 PM
FrankR Offline OP
I just took a closer look at the u-joint and pinion flange. It's definitely larger than what's on the Gen1 V6 Raider. The flange also looks like it would be very likely to hang up on a rock or be subject to damage more so than the smaller version.
Are the later SR locking differentials with the smaller pinion flange also 9.5"?
Frank
Re: '95 SR 3.5 w/Air Locker [Re: FrankR] #972271 11/20/09 11:18 PM
Why not redrill the flange and turn down the OD?
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6491 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-07-13 14:30:50 UTC
