Montero bellhousing #972322 11/17/09 12:33 AM
OldColt Offline OP
I am looking for an automatic bellhousing from a Montero.
It is time for me to get back to making adapters for manual transmission conversions and need some bellhousings to work with. I expect I may need a bellhousing from both an AW2 and an AW3.
Anyone have an unused one laying around?
Re: Montero bellhousing [Re: OldColt] #972323 11/18/09 06:49 AM
I think i saw a aw2 bellhousing at someones house, I'll keep an eye out. I have a bellhousing for a AW3 somewhere i think.
Re: Montero bellhousing [Re: TOASTY] #972324 11/18/09 04:31 PM
OldColt Offline OP
Thanks Toasty,
In some ways the automatic housing may be easier to work with. At least once I can get the parts drawn.
Re: Montero bellhousing [Re: OldColt] #972325 11/19/09 07:50 AM
If you're going to be making adapters could you use bellhousings off of V5MT-1's I can get you two of those
Re: Montero bellhousing [Re: TOASTY] #972326 11/19/09 12:32 PM
OldColt Offline OP
I have one manual housing here and I can make it work.
What I am doing at this time
The AY6 gearbox has an integral bellhousing that I will be cutting off. This leaves me with a row of perimeter fasteners to work with. The AY6 had a 9" depth within the bell that I need to shorten a few inches so the finished unit comes out the same length as the AW3 it will be replacing.
What the automatic bell may offer me is that the more open rear section might adapt easier once I can get these all drawn up.
I also can make adapters to the MA5 and AX15 gearboxes and the auto bell should be better for them too.
If what I am working on pans out I will have about 6 different gearboxes to mate behind these engines. This will be for both car and truck use. Most of these will be bolt on, the one I am doing now is more complex.
Re: Montero bellhousing [Re: OldColt] #972327 11/19/09 08:15 PM
Charlie, what does the 1991 model Montero use? I have a potential donor for your use if this works.
Russell
Re: Montero bellhousing [Re: rxinhed] #972328 11/20/09 12:44 AM
OldColt Offline OP
Hi Russell,
That would be the predecessor of the AW2. I expect it is the same transmission under a different name. Not that I can remember the numbers right now.
Kevin C. would know.
Re: Montero bellhousing [Re: OldColt] #972329 11/20/09 07:39 AM
exactly the same bellhousing.
Re: Montero bellhousing [Re: OldColt] #972330 11/22/09 07:40 AM
no v6 bellhounsings only a bunch of 5 spd ones sorry man.
Re: Montero bellhousing [Re: TOASTY] #972331 11/22/09 06:47 PM
OldColt Offline OP
Thank you Toasty.
Russell, I expect I will get that housing from you. I do not need that one right away since that will be for a car transmission swap that will follow this one I am working on.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.003s) Memory: 0.6459 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-06-17 03:27:18 UTC
