Page 4 of 5 1 2 3 4 5
Re: 88 Gen 1 SWB TSI Build Thread [Re: plh] #972371 05/31/10 11:13 PM
plh Offline OP
Turbo ID? My guess is a T3. Can't seem to find a map.
Intake side .42 A/R
Exhaust side .53 A/R
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: 88 Gen 1 SWB TSI Build Thread [Re: plh] #972372 06/01/10 12:14 AM
PhyrraM Offline
When I did mine, I used all the Montero bracketry and accessories. I don't recall any fitment issues with the A/C. I do know that I never even discharged the A/C system (or the P/S for that matter).
That turbo seems aftermarket. I'm pretty sure that all the OEM StarQuest turbos were Mitsu TD05-series. I would *guess* a T4 series turbo.
'95 white SR, 33x13.5 Yokos, stock otherwise
.....and a few Subarus.
Re: 88 Gen 1 SWB TSI Build Thread [Re: plh] #972373 06/01/10 08:48 PM
TainterRacing Offline
I would guess that turbo is a t3 45trim here is a flow map.
As that's the most common one for that housing.
Its about the same size as a stock Turbo(12a)
T3 .42ar 45 trim
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: 88 Gen 1 SWB TSI Build Thread [Re: TainterRacing] #972374 07/21/10 07:32 PM
plh Offline OP
Mid July Update:
Still moving along at a snails pace. This is where I am at:
Clearwater Head: $460 delivered with upper end Felpro gaskets & ARP studs.
Lower Gaskets: Felpro - $54
Cam Timing Kit: $47
Balance Shaft Timing Kit: $70
Freeze Plugs: $12
Clevite Oil Pump: $60
Oil Pump Pick-up: $15
Montero Oil Pan: $30
Purchased so far: $748
In Budget:
I have not opened my donor yet so have not bought bearings or rings - depends on if machine work is required for sizing.
Last I checked: Block Machining (if needed) runs about $400
Block cook only: $60
Crank (if needed) machining and balance: $250
Crank polish and clean: $80
Rings only: $65
Rings & H.U. Pistons (if boring block or OE are damaged): $165
Piston to Rod install: $50
Rod Bearings: $25
Main Bearings: $35
misc: $250
What am I missing?
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: 88 Gen 1 SWB TSI Build Thread [Re: plh] #972375 07/21/10 09:16 PM
Hoses and belts and filters....
Re: 88 Gen 1 SWB TSI Build Thread [Re: fasteddy] #972376 07/22/10 12:28 AM
plh Offline OP
Yep, That is in the Misc...
Putting in a new water pump in my N.A. today so I figured I'd take the radiator in to get cleaned in prep for the TSI.
Might be more difficult than I thought. Not many radiator shops around here any longer. When (if) I find one, what service do I ask for? I've heard it coined here as "rodding" is that a common term?
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: 88 Gen 1 SWB TSI Build Thread [Re: plh] #972377 07/22/10 12:43 AM
You want it rodded, or you want a new core. The starion rad will fit, but it's a 2 row, and you want the stock monty 3row. flushing is a waste of time and money...
Re: 88 Gen 1 SWB TSI Build Thread [Re: fasteddy] #972378 07/23/10 03:23 AM
plh Offline OP
Doing a visual on my radiator inside it looks pretty clean. I called what appears to be the only true radiator shop in my 1.5 million metro area and they want $150 for a rod job. So I am going to try a Muriatic Acid soak for 15 to 30 minutes rinse - repeat - neutralize and call it good. Rock Auto gets $200 for a new replacement.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: 88 Gen 1 SWB TSI Build Thread [Re: plh] #972379 07/24/10 02:26 AM
Jamez Offline
Sweet, I'll definately be following this thread. Got a lead on a complete '88 Conquest myself, hoping to have it here in a few weeks if it all works out <img src="/forums/images/graemlins/kewl.gif" alt="" />
Will you have pics of each step as you go?
Re: 88 Gen 1 SWB TSI Build Thread [Re: plh] #972380 09/06/10 01:04 PM
plh Offline OP
early September update:
Lots more parts obtained:
Modded Magna MPI Intake and Fuel Rail.
Threadstone T3 Exhaust Manifold
Tial Wastgate
Tial BOV
I also picked up a Garrett 60-1 T3 turbo - doubt I'll use in the truck.
Planning on EDIS-4 so got a module, pigtail, VR sensor, mount, distributor plug. 36-1 trigger wheel and pulleys.
More to come later in the month.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6480 MB (Peak: 0.7538 MB) Data Comp: Off Server Time: 2026-06-07 04:23:20 UTC
