Re: 88 Gen 1 SWB TSI Build Thread
[Re: plh]
#972371
05/31/10 11:13 PM
Turbo ID? My guess is a T3. Can't seem to find a map. Intake side .42 A/R Exhaust side .53 A/R ![[Linked Image]](http://www.ns-micro.com/~phanson/pics/640_480/CIMG6539sm.JPG)
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: plh]
#972372
06/01/10 12:14 AM
When I did mine, I used all the Montero bracketry and accessories. I don't recall any fitment issues with the A/C. I do know that I never even discharged the A/C system (or the P/S for that matter).
That turbo seems aftermarket. I'm pretty sure that all the OEM StarQuest turbos were Mitsu TD05-series. I would *guess* a T4 series turbo.
'95 white SR, 33x13.5 Yokos, stock otherwise .....and a few Subarus.
[Re: plh]
#972373
06/01/10 08:48 PM
I would guess that turbo is a t3 45trim here is a flow map. As that's the most common one for that housing. Its about the same size as a stock Turbo(12a) T3 .42ar 45 trim
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
[Re: TainterRacing]
#972374
07/21/10 07:32 PM
Mid July Update:
Still moving along at a snails pace. This is where I am at:
Clearwater Head: $460 delivered with upper end Felpro gaskets & ARP studs. Lower Gaskets: Felpro - $54 Cam Timing Kit: $47 Balance Shaft Timing Kit: $70 Freeze Plugs: $12 Clevite Oil Pump: $60 Oil Pump Pick-up: $15 Montero Oil Pan: $30
Purchased so far: $748
In Budget:
I have not opened my donor yet so have not bought bearings or rings - depends on if machine work is required for sizing.
Last I checked: Block Machining (if needed) runs about $400 Block cook only: $60 Crank (if needed) machining and balance: $250 Crank polish and clean: $80 Rings only: $65 Rings & H.U. Pistons (if boring block or OE are damaged): $165 Piston to Rod install: $50 Rod Bearings: $25 Main Bearings: $35 misc: $250
What am I missing?
- '88 Raider: my OG
- '92 RS M/T: sold
- '14 OL GT
[Re: plh]
#972375
07/21/10 09:16 PM
Hoses and belts and filters....
[Re: fasteddy]
#972376
07/22/10 12:28 AM
Hoses and belts and filters.... Yep, That is in the Misc... Putting in a new water pump in my N.A. today so I figured I'd take the radiator in to get cleaned in prep for the TSI. Might be more difficult than I thought. Not many radiator shops around here any longer. When (if) I find one, what service do I ask for? I've heard it coined here as "rodding" is that a common term?
- '88 Raider: my OG
- '92 RS M/T: sold
- '14 OL GT
[Re: plh]
#972377
07/22/10 12:43 AM
You want it rodded, or you want a new core. The starion rad will fit, but it's a 2 row, and you want the stock monty 3row. flushing is a waste of time and money...
[Re: fasteddy]
#972378
07/23/10 03:23 AM
Doing a visual on my radiator inside it looks pretty clean. I called what appears to be the only true radiator shop in my 1.5 million metro area and they want $150 for a rod job. So I am going to try a Muriatic Acid soak for 15 to 30 minutes rinse - repeat - neutralize and call it good. Rock Auto gets $200 for a new replacement.
- '88 Raider: my OG
- '92 RS M/T: sold
- '14 OL GT
[Re: plh]
#972379
07/24/10 02:26 AM
Sweet, I'll definately be following this thread. Got a lead on a complete '88 Conquest myself, hoping to have it here in a few weeks if it all works out <img src="/forums/images/graemlins/kewl.gif" alt="" />
Will you have pics of each step as you go?
[Re: plh]
#972380
09/06/10 01:04 PM
early September update:
Lots more parts obtained: Modded Magna MPI Intake and Fuel Rail. Threadstone T3 Exhaust Manifold Tial Wastgate Tial BOV
I also picked up a Garrett 60-1 T3 turbo - doubt I'll use in the truck.
Planning on EDIS-4 so got a module, pigtail, VR sensor, mount, distributor plug. 36-1 trigger wheel and pulleys.
More to come later in the month.
- '88 Raider: my OG
- '92 RS M/T: sold
- '14 OL GT
