Page 13 of 15 1 2 … 11 12 13 14 15
Re: To get 30's or 31's ???? [Re: Hydra747] #972786 02/23/10 08:21 AM
blitz Offline
you would be surprised at how much nicer the ride without that swaybar.
yes the debate about saftey goes on.
just drive it like a truck without a swaybar and you would be good.
i got around that old man and through the colvert without flippin without mine.
warning however,if you try to loosen nuts they will most likly snap.i may have to put mine back on to pass inspection,but it will come right back off.
nice pics. cant wait to see my sport in a set of those.
Re: To get 30's or 31's ???? [Re: blitz] #972787 02/23/10 01:48 PM
jaboo5322 Offline
It fits the truck alot better now. Nice. <img src="/forums/images/graemlins/kewl.gif" alt="" /> And i'd like to second the swaybar, but that was in another discussion. <img src="/forums/images/graemlins/shiner.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: To get 30's or 31's ???? [Re: blitz] #972788 02/23/10 11:52 PM
6
69442 Offline
Won't that cause our Sportys to corner like a Winnebago <img src="/forums/images/graemlins/scared.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: To get 30's or 31's ???? [Re: 69442] #972789 02/24/10 01:24 AM
DamKia Offline
Kia Moderator
...........and they don't already????? <img src="/forums/images/graemlins/scared.gif" alt="" />
Agree with the comments about minus sway bar(s), but only when fitted with uprated springs. Mine handles better with a 2" bodylift, 2.5" spring lift, and 31" tyres than it did stock as a rock. The "chuckability" factor into a corner is far better, with minimal hopping through undulations mid-corner. More confidence inspiring handling.
Re: To get 30's or 31's ???? [Re: DamKia] #972790 02/24/10 09:43 AM
2002_Sporty Offline
Agree with the stiffer springs and cornering. Since my 3" lift, I have been able to corner at higher speeds. Safely.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: To get 30's or 31's ???? [Re: blitz] #972791 02/24/10 11:15 PM
Hydra747 Offline OP
My sway bar with drop links kinda rubs on the front of the lower arms.......
Is this what you mean Blitz??
Re: To get 30's or 31's ???? [Re: Hydra747] #972792 02/25/10 05:15 AM
6
69442 Offline
maybe it's time to unhook that bugger.
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: To get 30's or 31's ???? [Re: Hydra747] #972793 02/25/10 08:53 AM
blitz Offline
if its rubbin that really aint good. if you want to keep the sway bar ,do it right. lower the front brackets to retain original angle on swaybar. they work kind of like torsion bars,and by changing the angle steeper with a lift it makes the sway bar even stiffer.
sudden change in one direction without sway bar aint to bad,its when you need to correct, thats when there could be trouble.the return is where the extra sway will kick in. it could be bad.i definatley noticed that i needed to be careful.
so if you take it off you need to drive to accomodate. but for just comuting it was so much nicer. try it for a week and tell us what you think.careful with the nuts.liquid wrench and some heat for sure...
should this be a new thread under sway bar?...just askin.
geuss its my fault ,i started the sway bar stuff..anyway GREAT LOOKIN TIRES! more pics when the rears go on..
Re: To get 30's or 31's ???? [Re: blitz] #972794 02/25/10 09:30 AM
2002_Sporty Offline
I heard somewhere that you want to keep the front and rear diameter of the tires within 1/4" of eachother, and definatly under 1/2" of eachother if your running in 4 wheel drive. Am I correct? Can I drive around in two wheel drive with different diameter tires front and rear? It would be nice to have some mudders on the rear and some all terrain on the front, but I am worried about difficulty matching diameters with todays sizes and tread depth differences. Is this a possibility? Or am I just looking for trouble in the drivetrain?
Re: To get 30's or 31's ???? [Re: 2002_Sporty] #972795 02/25/10 11:07 AM
blitz Offline
i dont use 4wd unless i absolutley have to. even with the same size tires you can bind stuff up between the front and rear tires..i.e..."transfer case".
guy at work was telling me that he uses his 4wd in the rain on highway. in a jeep cj.why were we talikn about it,......he was getting a new transfer case.
that was about 6 months after he had got a new trans mission.
moral of story(i love that line) if you aint slippin and sliding,you will bind up your tansfer cs.so..if your slidin around that much, i dont think a small diameter differene will ruin you.
im picky about this topic.i would try to maintain the same size.but you can get away with a little for awhile.i also like to baby my transfer case chain.lotta work,time,money, to get in there.i dont beleive in a lead foot in the woods either.recipe for some breakage.sometime it has to be done.for the most part i try to just putt thru the trails. as soons as you hear people say "watch this" or "hold on" you can just get the block and tackle out...
now let me give you my philosophy on transendance and how to open your third eye..uhhg enough. <img src="/forums/images/graemlins/sleeping.gif" alt="" />
PHP: 7.4.33 Page Time: 0.638s Queries: 15 (0.480s) Memory: 0.6464 MB (Peak: 0.7552 MB) Data Comp: Off Server Time: 2026-10-26 04:45:52 UTC
