Page 14 of 15 1 2 … 12 13 14 15
Re: To get 30's or 31's ???? [Re: blitz] #972796 02/25/10 03:21 PM
6
69442 Offline
Ya Blitz is right, you'll be fine as long as their close ratios and you're not driving around on the street in 4WD.
I don't see any reason to be in 4WD in the rain, Sporty's don't have enough power to break loose even if you try!
The tire tread depth and circumference issues have more to do with AWD low tolerance transfer cases that engage all the time.
With that said, same tire size, tread design & depth is still the best way to go.
Just my 69 cents
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: To get 30's or 31's ???? [Re: blitz] #972797 02/26/10 12:58 AM
Hydra747 Offline OP
if its rubbin that really aint good. if you want to keep the sway bar ,do it right. lower the front brackets to retain original angle on swaybar. they work kind of like torsion bars,and by changing the angle steeper with a lift it makes the sway bar even stiffer.
I already have the sway bar drop links on....
should this be a new thread under sway bar?...just askin.
Thanks for being kind.....But it could be relative for tire size and also safety! <img src="/forums/images/graemlins/kewl.gif" alt="" />
I will take a crow bar and bend it a bit cause it is rubbing against the lower arm....
Re: To get 30's or 31's ???? [Re: Hydra747] #972798 02/26/10 06:28 AM
blitz Offline
hydra..im not sure if im right on this.im thinking maybe...your sway bar is upside down.
also it may bolt onto the top of a-arm bolt end.(you would need to rotate the cap end with the bolt threads to point up)
like i said im not sure and mine is off,but this warrants investigation.
either bolted on wrong side,or upside down,or both.
something just doesnt seem right. we need a pic of original setup.
Re: To get 30's or 31's ???? [Re: blitz] #972799 02/27/10 12:44 AM
Hydra747 Offline OP
Good point.....!
Look at the very bottom of the skid plate to the forks:
Does it look right???
They are attached to the bottom of the forks.......
Re: To get 30's or 31's ???? [Re: Hydra747] #972800 02/27/10 12:45 AM
Nukeiridium Offline
Good point.....!
Well either mine is on wrong or yours is. Mine sits above the mounting bolts not below like yours.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: To get 30's or 31's ???? [Re: Nukeiridium] #972801 02/27/10 12:53 AM
Hydra747 Offline OP
Thanks guys....Mine is wrong!!!!!!!!
Nuke, how do I fix it?
Can I see how your setup is??
Re: To get 30's or 31's ???? [Re: Hydra747] #972802 02/28/10 04:43 AM
FOURSKIA Offline
Hydra, when u fix yours or if anyone else has them on correctly can you post a pic so we can see? <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Sportage, 75mm lift, 30"s A/T,UHF& HF, AVM hubs and more to come.
Re: To get 30's or 31's ???? [Re: FOURSKIA] #972803 02/28/10 05:00 AM
jaboo5322 Offline
The bolts that hold the ends of the swaybar to the fork bolt are on like a ball joint. Unbolt them, and turn them facing up instead of down. Then reattach swaybar. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: To get 30's or 31's ???? [Re: jaboo5322] #972804 02/28/10 05:04 AM
jaboo5322 Offline
You say you do have the drop links? I had to move the swaybar under the original skid plate with the droplinks to attach the swaybar. I have dave's kit. I would take pictures, but of course i don't use my swaybar. <img src="/forums/images/graemlins/notooth.gif" alt="" />
1989 Dodge W250.
Re: To get 30's or 31's ???? [Re: jaboo5322] #972805 02/28/10 10:18 AM
Nukeiridium Offline
Same here my swaybar is under/outside of the skid plate.
Which makes it easier to remove anyway when wheeling...
PHP: 7.4.33 Page Time: 0.015s Queries: 14 (0.012s) Memory: 0.6468 MB (Peak: 0.7568 MB) Data Comp: Off Server Time: 2026-10-26 03:40:49 UTC
