leaf spring issue
#973966
11/26/09 03:55 AM
Have late model Tacoma leafs on the rear of my '81 Toyota. Driverside rear is having a problem. The lowest/thickest leaf won't stay in line with the rest of the pack. It turns. I've tried re-tourqing the U-bolts and it still moves after a run. Anybody know what the deal is? The passenger side does not do this. The same thing happened with my old leafs to the point that it rubbed on the tire and blew it. Seems the new ones want to do the same but they are angled different and can't actually contact the tire. Any suggestions?
Re: leaf spring issue
[Re: xrtim]
#973967
11/26/09 04:49 AM
You could try putting a spring clamp on one end of the other to hold the bottom leaf in line with the rest of the pack. Either drill the end of the leaf and bolt/rivet in a clamp or use one of the bendable clamps. I added a clamp to the back end of my front springs: ![[Linked Image]](http://www.4crawler.com/4x4/CheapTricks/Images/Phase-III/Faxle6.jpg)
[Re: 4Crawler]
#973968
11/27/09 06:11 PM
I could do that but the design of this spring is such that it is several inches away from the rest of the pack. In fact, it's inverted a bit because the last leaf is actually like an overload leaf. I've looked at the original truck they came on and everything is correct. I need to keep it in the pack but wish it wouldn't turn. I may go the spring keeper route but wanted to investigate first because they didn't come that way stock. Something is going on with my truck and I wanna figure it out. Thanks for the info a pics though.
[Re: xrtim]
#973969
11/27/09 11:51 PM
The earlier rear springs have a tall spring clamp on the end of the overload leaf. It is tall enough to reach the top of the spring pack and has a sleeve and bolt that go over the top. It helps keep the spring in line and also works as an anti-wrap device as the back end of that leaf bends down under load, it pulls on the rear of the spring pack.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6027 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-11-16 04:20:54 UTCValid HTML 5 and Valid CSS
