Page 2 of 6 1 2 3 4 5 6
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: Mudraider] #974022 11/28/09 12:58 AM
Temple Offline
My 3.0 SWB is a 19.7tank
I wouldnt get any where ever with a 13gal.
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: Mudraider] #974023 11/28/09 05:34 PM
justice Offline
So you guys with the LWB 3.0 engines only have a 13 gallon tank? LM <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> off at Mitsubishi's faux pas on that.
Who said that? The 3.0 SWB is around 18 and the LWB is a bit more maybe 23?
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: justice] #974024 11/28/09 06:22 PM
Bernoulli Offline
I believe the SWB is 75L and the LWB is 92L.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: Bernoulli] #974025 11/28/09 08:43 PM
TrailRaider Offline
Info pulled from printed Mitsu brochure's.
'87 Raider (99% sure Monty would be the same for the year)
15.9 gallon tank.
'90 Montero
SWB 19.3 gallon
LWB 24.3 gallon.
I'd scan and paste, but I dont have a scanner :-)
'89 Raider V6 auto.
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: TrailRaider] #974026 11/29/09 12:00 AM
SandRaider Offline
If it's offroad only, definately put a fuel cell in. you don't have to worry about crushing a tank anymore and it can help your departure angle
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: SandRaider] #974027 11/29/09 12:56 AM
Mudraider Offline OP
SO has anyone tried putting the bigger 6 cylinder tank in the 4 cylinder trucks? Fabbing up a fuel cell is out of the question for me right now.
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: Mudraider] #974028 11/29/09 05:45 AM
zarktheshark Offline
did a quick search as i thought this has come up before and it does not look like the v6 tank will bolt right in.
link
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: Mudraider] #974029 11/29/09 07:44 AM
LandRaider Offline
No, because it won't fit in between the leaf springs.
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: LandRaider] #974030 11/29/09 08:01 AM
DRaider90 Offline
I wonder with the 2" body lift installed if you did the gas tank lift (that Mark and others have done) but instead of putting the 4 Cyl Tank back would you then be able to squeeze the V6 tank in between the leaf springs? I don't know the design of the gas tank so I can't mentally picture it in my head.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: Is there a bigger gas tank for the Gen 1's that is a bolt in? [Re: DRaider90] #974031 11/29/09 08:25 AM
LandRaider Offline
No.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6463 MB (Peak: 0.7507 MB) Data Comp: Off Server Time: 2026-06-20 22:48:51 UTC
