Page 6 of 6 1 2 3 4 5 6
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: LRJ4x4] #974062 12/05/09 02:32 AM
GreatWhiteShark Offline
do the V6 Montero's have a bigger gas tank than the 4 cylinders? The 13 gallon one in the MudRaider is just silly. I swapped a 20 gallon one from a different S-10 into my originally equipped 14 gallon tank S-10, wondering if that is possible or even an option?
Try being out West with a Gen 1 ! That tank is way to small for the MPG it gets.
sorry to hijack....any close ups of that gas can mount?
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: GreatWhiteShark] #974063 12/05/09 02:39 AM
0778drz110 Offline
good luck, he no longer owns that SWB any more
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: GreatWhiteShark] #974064 12/05/09 05:49 AM
Oyaji_Jon Offline
I think I have one like it sitting on the shelf in the garage, Kris. I'll see if I can get a pic up this weekend.
EDIT: Here's a shot of what I think is the same gas can mount on my old White Monty.
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: Oyaji_Jon] #974065 12/05/09 06:25 AM
Thank You. not quite what i thought i was going to see. but still cool. by the way my name is Ben.
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: GreatWhiteShark] #974066 12/05/09 06:41 AM
Oyaji_Jon Offline
Ok, Ben.
That holder is a clamp of sorts. The little round "eye" on top is a screw that tightens the top plate onto the lip of the gas can as it turns. On the back of the aluminum piece was a piece of U-channel that I thought was cheesy, so I ground it off and welded a piece of one sized pipe to the plate that bolts to the tire mount and a larger size pipe to the plate that mounts to the "clamp" assembly. I then slipped the small pipe into the larger pipe and drilled a hole all the way through so a pin can be put in to make a quick release for the clamp. That made mounting the spare easier and I'm able to put other "attachments" on there with the right size of pipe.
Anyway, more info than you asked for, but there it is...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: Oyaji_Jon] #974067 12/05/09 04:36 PM
That is Fantastic! Now i have a idea and i will get on it Sunday. smile <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: GreatWhiteShark] #974068 12/06/09 01:08 AM
89Montiero Offline
Is that a land rover discovery ladder on the back of your white Montero? I saw one the other day and was wondering if it would fit a gen I and it looks like it does. Great! Did you have to modify it to fit at all?
thanks,
1989 Mitsubishi Montero SWB V6. Torsion bar crank, Gen II springs, 31X10.5" BF Goodrich M/T's
2005 Mitsubishi Montero Limited 3.8 V6
2011 Subaru Impreza Outback Sport
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: 89Montiero] #974069 12/06/09 01:15 AM
0778drz110 Offline
thanks,
yes it is, do a search for ladders there was some talk a couple weeks ago <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: 0778drz110] #974070 12/06/09 07:00 AM
The Disco ladder can be readily made to fit.
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: 0778drz110] #974071 12/06/09 08:39 AM
Oyaji_Jon Offline
thanks,
I'm glad you know what was on my truck because I can't confirm what it was supposed to be for. It was on there when I bought it.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6447 MB (Peak: 0.7555 MB) Data Comp: Off Server Time: 2026-11-19 05:34:24 UTC
