Rear Brakle Lines Rusted #974567 12/01/09 11:41 PM
G
GreyDuck Offline OP
My truck is suffering from rusted brake lines. The local dealership says I can get both rear lines pre-bent for about $100 (there are a lot of bends in these lines and I can't see what's going on over the gas tank) Or, I could get some generic straight lines for about $20 from the local parts store. Is it worth the extra $80 for the factory lines? I've bent a few lines in the past but these are quite a bit longer and they have many bends. If I do go with the generic lines how long should I get, is 72" long enough?
Also, is the best way to replace these to remove the box? It seems a lot easier than removing the gas tank. Or, should I use the generic lines and run them somewhere else?
As always, thanks for your time and advice! It is appreciated.
GreyDuck
1990 Truck 4X4 5sp 22re
Re: Rear Brakle Lines Rusted [Re: GreyDuck] #974568 12/02/09 12:49 AM
CJMT100 Offline
I would cut the lines from a part where it isnt rusted and use a compression fitting there.
Re: Rear Brakle Lines Rusted [Re: CJMT100] #974569 12/02/09 01:38 AM
4x4runner Offline
I just went through the same deal on my '95 4 runner. I ordered the factory beake lines from the dealer, but they were not the same as the factory lines. I ended up cuttin g the rusted line and installed a compression fitting. My brakes are great and no leaks. Cost me about $4.00 and was much easier than replacing the entire brake line.
Re: Rear Brakle Lines Rusted [Re: 4x4runner] #974570 12/02/09 05:19 AM
CJMT100 Offline
Also remember, so long as you tuck the line sup good you dont have to follow the old lines 100%.
Re: Rear Brakle Lines Rusted [Re: 4x4runner] #974571 12/03/09 08:26 PM
MAC Offline
What kind of compression fitting did you use? oem line is 6mm ?
Re: Rear Brakle Lines Rusted [Re: MAC] #974572 12/04/09 04:14 AM
CJMT100 Offline
They sell metric lines and fittings, go to the parts store and ask tbh.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6742 MB) Data Comp: Off Server Time: 2026-06-10 18:05:54 UTC
