Rear end question #974636 12/02/09 07:01 AM
88D50 Offline OP
I have an 89 1500 step side. A friend has a 91 1500.
My truck had the 4.3 V6, and my fried has a V8. My question is, can I use the rear axle from my truck in my friends truck? His rear end blew out and needs the truck for work.
Also, would the ratio be the same?
Re: Rear end question [Re: 88D50] #974637 12/03/09 05:08 AM
The rear axles should be compatible. The automakers finally stopped the silly 60's practice of having different grade drivetrain bits depending on engine size. The gear ratio may be different for auto / stick trans and will be biased toward a high numeric gear (like 3.08:1)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5867 MB (Peak: 0.6343 MB) Data Comp: Off Server Time: 2026-06-16 13:51:04 UTC
