Blown upper radiator hose, white goop under cap #975262 12/06/09 01:02 AM
yodta Offline OP
Blown head gasket most likely, or cracked head. been getting intermittent white goop under the cap off and on for a few months now. initially thought it was due to the overnight temp swings of the seasons changing -- common symptom of Head Gasket Failure Denial.
so what happens here? cylinder gasses pressurizing the cooling system, and boom? I don't know much about the cooling jackets and where they run through the head and block, but I'm assuming there's a gasket leak near one of the cylinders.
also seem to be getting some blow-by as well. I'm noticing a film of oil collecting around the breather I have on the front of my valve cover.
I can only imagine the expression on my face when this thing let loose smile
msg - '87 xtracab
Re: Blown upper radiator hose, white goop under cap [Re: yodta] #975263 12/06/09 04:42 AM
yota4runna Offline
The coolant passages are only about 1/4" away from the cylinder. It's surprising that more head gasket failures don't have catastrophic results like yours. After all, 150 psi compression pressure getting into a cooling system designed to run at 15 psi could blow up a radiator or heater core, as well as a hose.
Re: Blown upper radiator hose, white goop under cap [Re: yota4runna] #975264 12/06/09 05:00 AM
yodta Offline OP
isn't that what the radiator cap's for?
I never heard any boil over.
Wonder how frequently caps go bad.
got some info from EB. will check out a few things and post back if I find anything interesting.
msg - '87 xtracab
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5940 MB (Peak: 0.6485 MB) Data Comp: Off Server Time: 2026-05-29 20:48:49 UTC
