cigarette smell removal?
#975521
12/08/09 12:02 AM
Hey guys, I'm contemplating diving in a buying my first SWB. A lcoal has one for sale at $1000, thinking of offering $700 since it's been smoked in and apparently needs an O2 sensor.
I'm checking all the usual off-site search engiens, and I tried searhcing here as well, jsut wondering what my fellow wire users have used to remove cigarette smell from a rig that ~20 years old
Right off the bat I've thought of loading it up with several baking soda trays/boxes.... A gallon of Febreze?
Or am I doomed to smell cigarette ash forever if I buy this thing?
MI-Mitsu
89 Montero LS 3.0L/Auto 90 MightyMax 2.4L/Man
Parted/gone - parts available! 89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2) 89 Conquest SHP 88 Conquest SHP 87 Dodge Raider 2.6L/Auto 91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: cigarette smell removal?
[Re: MI_Mitsu]
#975522
12/08/09 12:05 AM
just found this: How to do things still wondering what others here have tried..what worked...what didn't. Jim/MI-Mitsu
[Re: MI_Mitsu]
#975523
12/08/09 01:05 AM
Clean the inside really well with 409 or similar, use a carpet cleaner and upholstery spray, then put a couple of trays of plain old charcoal briquettes under the seat and change them every couple of months, or so - whenever needed. The smell will be gone in a day or so.
Frank
[Re: FrankR]
#975524
12/08/09 01:27 AM
...then put a couple of trays of plain old charcoal briquettes under the seat and change them every couple of months, or so - whenever needed. ...The smell will be gone in a day or so. Those two don't add up. <img src="/forums/images/graemlins/wink.gif" alt="" /> Yes, do what Frank suggests... even though these 2 don't add up.
[Re: off-roader]
#975525
12/08/09 02:22 AM
the link you found has some good ideas. a friend that works in autobody says he puts a sliced apple in a bowl and it works, but I didn't think so. I ended up wiping down everything, used a fair amount of fabreez on the seats and chucked the carpet. the carpet held most of the smell, so when i pulled it, smell was pretty much gone. my carpet was junk, so i didn't try cleaning it, but i would think that pulling it out and washing it would have done wonders.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
[Re: MI_Mitsu]
#975526
12/08/09 02:30 AM
BG Frigifresh. That stuff is awesome. Even works on cigar smoke smell.
'97 Montero Sport LS 5-Speed 3.5L conversion SAS Dana 44s & ARBs, 35" Yoko Geolandar M/Ts NP231 B4R doubler/Terra Low231/RP 5.38 229:1 '99 Montero Sport Limited 4WD SAS 3-link project '03 Montero Sport Limited AWD '97 Montero Sport LS 5-Speed 4WD
[Re: off-roader]
#975527
12/08/09 02:37 AM
Yes, do what Frank suggests... even though these 2 don't add up. Well, you have to know how to add 2+2 and get 10. <img src="/forums/images/graemlins/wink.gif" alt="" /> The source of the odor will last a long time because the fibers are saturated and will continue to give off odor for a long time. The charcoal will absorb what's in the air and quickly catch up to the odor emission rate. But, after a while, the charcoal becomes saturated and must be replaced. If you don't replace the charcoal, the odor will return. Perhaps in many years, all odor will be gone, but one tray of charcoal just won't last that long. <img src="/forums/images/graemlins/wink.gif" alt="" /> Look at it as a bucket under a drippy roof. It'll hold the water for a while, but eventually, you'll need to replace the bucket.
[Re: FrankR]
#975528
12/08/09 02:43 AM
The biggest problem with the 2nd hand stench is ionic. I'll probably get this backwards but on synthetic fabrics there is a free ion at the end of polyester, el. al., that bonds with some of the stinch molicules in the smoke. I don't know how to reverse that bond. Simple green will get it on surfaces but I don't know how you will ever get it out of the foam and fabric.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: FrankR]
#975529
12/08/09 02:44 AM
leave an open can of ammonia (sp?) in the car for a couple days. That should help about 95%
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: MBrannon]
#975530
12/08/09 05:35 AM
Ammonia...
Yep, leave a couple of rabbits in the truck to pi$$ on the carpet for a couple of days. You sure won't smell the smoke anymore, I promise! <img src="/forums/images/graemlins/kewl.gif" alt="" />
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
