Re: Need Bouncy Seats for 1990 Gen 1 Montero (passenger side) [Re: RockDoc] #976204 01/11/10 06:35 PM
Chief Offline
I have one. Ready to be converted as you wish.
$50.00 USD + shipping.
PM me if interested.
'89 Raider V6, AT, SAS'ed, Dana 44 front & rear, 5:38 gears, NP 231 T-case.
'97 Montero SR, cold weather package, 4.90 R&P, BATTLEZ suspension w/ 2" lift, JAOS grill guard & under body protection, custom rock sliders.
Re: Need Bouncy Seats for 1990 Gen 1 Montero (passenger side) [Re: Chief] #976205 01/12/10 01:22 AM
RockDoc Offline OP
Hi Chief:
Do you have a pic of your seat frame? I'm looking for the version that fits directly into the passenger side (other versions require mods to flip the adjustment knob so it does not run into the raised body between the seats. Also, does yours have six bolts, or 4 to attach to the underlying frame?
Thanks! - RockDoc
1990 SWB Montero, 3.0l auto, ARB lockers, OME suspension, 32' BFG AT's, PIAA light upgrade.
Re: Need Bouncy Seats for 1990 Gen 1 Montero (passenger side) [Re: RockDoc] #976206 01/12/10 02:31 AM
There are no mods necessary to place the bouncy seat base on the passenger side. The adjuster knob clears everything. Those folks who've switched the knob sides did so for aesthetic reasons. Second, the 6-bolt frame is simply a 4-bolt frame with two extra tabs welded on, just cut them off or bend them out of the way. Simple.
The only way to get you a factory 4-bolt unit with a right side knob will be from an RHD Mitsu.
Re: Need Bouncy Seats for 1990 Gen 1 Montero (passenger side) [Re: RockDoc] #976207 01/12/10 06:21 AM
Chief Offline
Hi Chief:
Thanks! - RockDoc
I'll post some photos tomorrow.
Re: Need Bouncy Seats for 1990 Gen 1 Montero (passenger side) [Re: Chief] #976208 01/16/10 02:17 AM
Chief Offline
Here you go.
No mod is necessary to the adjustment know; will work on the passagenr side as is. The rear tabs can be cut off or floor can be drilled and bolted through.
PM me if you are interested.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6124 MB (Peak: 0.6770 MB) Data Comp: Off Server Time: 2026-06-12 16:01:10 UTC
