gear oil capacities for 88 montero swb been broke for over a year
#976485
12/15/09 12:47 AM
I haven't been on in a while and I tried to search. the new way topics are displayed is quite frustrating. I need to know what the best gear oil is and what is the capacity of my gear box and transfer case. I have a 1988 montero swb 5 speed. any help will be greatly appreciated. I know some people say search for hours its easy but if you have any info I would appreciate your time thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 montero 3'' body lift, torsion crank, shackles, 32'' tires 200,00 miles and going
Re: gear oil capacities for 88 montero swb been broke for over a year
[Re: barlown]
#976486
12/15/09 04:38 AM
1987 FSM Page 0-7
Lubricant Capacities Table for 4-cyl model:
Engine Oil 5.3 quarts Cooling System 8.45 quarts Manual Transmission 4.7 pints Automatic Transmission 15.2 pints Transfer case 4.7 pints Front Axle 2.3 pints Rear Axle with no LSD 2.3 pints Rear Axle with LSD 3.8 pints Power Steering 1.9 pints Fuel Tank 15.9 gallons
I filled with Valvoline the past oil change sequence for the gear boxes and axles. I use Castrol for the engine. Gas is what-is-near.
Cheers, Russell
[Re: rxinhed]
#976487
12/15/09 05:25 AM
thanks a million <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: rxinhed]
#976488
12/15/09 05:32 AM
1987 FSM Page 0-7 Rear Axle with no LSD 2.3 pints Rear Axle with LSD 3.8 pints
I'm trying to get my arms around this one... doesn't make any sense to me.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: plh]
#976489
12/15/09 07:36 AM
I would assume the open axle doesn't require the care in oiling the LSD does. Same type of note was in my 1968 Buick manual. <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6066 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-07-15 09:15:02 UTCValid HTML 5 and Valid CSS
