power brakes #977006 12/19/09 12:54 AM
I
itswrongway Offline OP
what kind of adjustments do I need to make after I replace the power brake vacuum can on my 01 escape ?
Re: power brakes [Re: itswrongway] #977007 12/19/09 04:08 AM
There should be no adjustment to the power booster. Is this your question? There should be a one-way valve that fits in the vacuum hose that connects the booster to the engine manifold. There are no field adjustable parts in the booster.
To replace the booster, most vehicles have clearance issues with the brake line plumbing. If you have to remove the booster and master cylinder together, you'll have to detach whatever brake line fittings, reassemble and bleed the brake hydraulics. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.019s) Memory: 0.5862 MB (Peak: 0.6340 MB) Data Comp: Off Server Time: 2026-05-29 20:17:33 UTC
