1999 Headlight Switch Replacement #977754 12/23/09 10:20 PM
Y
yotadiehard Offline OP
How do you replace the headlight switch in a 1999 Ford F150 4x4. Parking lights will not turn off. My dad has to disconnect the battery every time he parks it. I need to replace it for him.
Re: 1999 Headlight Switch Replacement [Re: yotadiehard] #977755 12/25/09 04:47 AM
kewlynx Offline
Sure it's not the headlight relay? You should be able to find some wiring diagrams at www.autozone.com
**ubi apis- ibi salus**
Re: 1999 Headlight Switch Replacement [Re: yotadiehard] #977756 12/27/09 06:46 PM
Y
Where is the headlight relay located and how do you test it?
Re: 1999 Headlight Switch Replacement [Re: yotadiehard] #977757 12/28/09 08:55 AM
kewlynx Offline
Dunno. I stay away from Ferds. <img src="/forums/images/graemlins/barf.gif" alt="" /> Open the hood and look around.
If he has a Chiltons or Haynes laying around, grab it.
If you're actually referring to DRL's, then read this; Google is your friend if you know what you're looking for.
http://www.fordf150.net/howto/drl.php
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6038 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-05-30 00:11:52 UTC
