What's a good quality radiator for a 1990 3.0l SWB Montero? #978761 01/01/10 07:08 AM
RockDoc Offline OP
Anybody have any recommendations for a replacement radiator for a 1990 3.0l Montero (SWB). Mine started spewing coolant yesterday. OEM Mitsu radiator is expensive, $480. Others like Silla are less than $200. Wadda think? Loioking for quality at a reasonable price. Thanks! Rockdoc
1990 SWB Montero, 3.0l auto, ARB lockers, OME suspension, 32' BFG AT's, PIAA light upgrade.
Re: What's a good quality radiator for a 1990 3.0l SWB Montero? [Re: RockDoc] #978762 01/01/10 08:32 AM
Oyaji_Jon Offline
Good quality can be had.
Inexpensive monetary cost can be achieved.
Both generally can't happen in the Mitsubishi 3.0L cooling dept.
I had my factory radiator recored to 3 rows at a local shop for $450 and wouldn't do it differently if faced with the decision again. Lots of people have asked the same question you ask now. Aftermarket radiators are hit and miss. I think Larry (hazydaze) may have a decent brand.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: What's a good quality radiator for a 1990 3.0l SWB Montero? [Re: Oyaji_Jon] #978763 01/01/10 01:32 PM
Va_Stumpy Offline
http://www.yourautocoolingsource.com/site/823209/product/CU1384
This is what I used.All metal construction,identical to the stock 1.Bolted up perfectly.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: What's a good quality radiator for a 1990 3.0l SWB Montero? [Re: Oyaji_Jon] #978764 01/01/10 05:05 PM
Happy Birthday hazy_daze Offline
NAPA was being supplied by Proliance (they bought Modine several years back) but due to them not keeping up with NAPA's demand, they were dropped as a supplier. They made a very good product when they were Modine and better than average one as Proliance. The current supplier is Spectra, a Canadian company that sources most numbers from China. They're making a fairly decent product, so far. I've had zero warranty issues since the changeover and I sell ALOT of radiators a month. I'm currently running one in my truck and have no issues with it other than it's slightly lighter gauge than that of OE. Justice ordered one that came in from Spectra and he didn't like it. Reordered one from Proliance and IIRC, said it was acceptable. He's deployed right now, but he may chime in at some point. HTH.
Re: What's a good quality radiator for a 1990 3.0l SWB Montero? [Re: hazy_daze] #978765 01/01/10 05:45 PM
justice Offline
The problem I had with proliance was that the first one I installed leaked, the second was damaged in shipment. The packaging is poor which I believe caused the leak in the first by bending the AT cooler connectors and the of course the second one which was bent all up at the main inlet. After all the hastle they told me they were out of stock and couldn't get a third one in. So yea, I was forced to use a POS plastic tank model due to upcoming trip..Going to replace that with JY OEM when I get back.
Thanks, going with Proliance... [Re: Va_Stumpy] #978766 01/01/10 10:32 PM
RockDoc Offline OP
OyajiHazyJusticeStumpy:
I'm gonna go with a Proliance radiator. Will pick one up tomorrow at a Denver distributor. Thanks! <img src="/forums/images/graemlins/smile.gif" alt="" /> RockDoc
Re: Thanks, going with Proliance... [Re: RockDoc] #978767 01/02/10 12:58 AM
FWIW, I got my stock tanks recored with a custom, high fin count high tube count 3 row for about $250 about 3 years ago.
Re: Thanks, going with Proliance... [Re: fasteddy] #978768 01/02/10 04:04 AM
MI_Mitsu Offline
my only radiator experience thus far has been a Sela unit ordered thru an independent local dealer about 3 years ago. within the first 30 days it started leaking at the top tank weld. Replaced under warranty, the 2nd unit hasnt been a problem since.
Jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: What's a good quality radiator for a 1990 3.0l SWB Montero? [Re: RockDoc] #978769 01/02/10 05:20 AM
sasnydley Offline
I replaced my few years back. I think it was radiator.com or somthing. 1st was damaged- Called they overnighted me one no Questions asked. Switched box- had some local guy deliver it. Was all metal. And has had no problems.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6296 MB (Peak: 0.7332 MB) Data Comp: Off Server Time: 2026-06-23 00:52:42 UTC
