Clutch-4 rnr #978881 01/01/10 11:32 PM
RustNeverSleeps Offline OP
The saga continues: the clutch was needing to be punched to the floor with the point of my toe to grind it down far enough for me to shift. I adjusted the pedal as much as I could; couldn't back the master cylinder pin out any further or it would've fallen out of the T-pin thing. Still engages pretty far down. While under the dash I noticed a split in the clutch bracket. It didnt seem to be moving when I was engaging the clutch, but maybe it's been push down/bent and that's why the master cylinder pin can't back out far enough??? It doesn't look very fun to replace. <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Clutch-4 rnr [Re: RustNeverSleeps] #978882 01/02/10 05:15 AM
Adam F Offline
Its possible.
Can you weld it?
97 4R, stock, daily driver
Re: Clutch-4 rnr [Re: Adam F] #978883 01/02/10 06:25 AM
OOP'S Offline
Not a real common problem but it does happen. Replace or weld, it is your choice. Either one is a bummer to do.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clutch-4 rnr [Re: OOP'S] #978884 01/04/10 02:06 AM
Replace looks to be pricey (like $200), but I sold my welder with the divorce (10 years ago). Replacing that's even pricier <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Clutch-4 rnr [Re: RustNeverSleeps] #978885 01/04/10 02:52 AM
OOP'S Offline
There is still some welding to do with the new bracket.
David Fritzsche
Roseville, CA
Re: Clutch-4 rnr [Re: OOP'S] #978886 01/04/10 02:54 AM
Shoring up the welds on the new one?
Re: Clutch-4 rnr [Re: RustNeverSleeps] #978887 01/04/10 02:56 AM
kewlynx Offline
Doesn't that guy in Palmer have Toys in his yard?
www.car-part.com
I'd probably yank the seat out of the way to do a bracket R&R.
**ubi apis- ibi salus**
Re: Clutch-4 rnr [Re: kewlynx] #978888 01/04/10 03:17 AM
That's not too bad an idea (the seat thing). I should look for a used bracket?
Re: Clutch-4 rnr [Re: RustNeverSleeps] #978889 01/04/10 03:27 AM
kewlynx Offline
I would if you're not going to yank your old one and have someone reweld for you. I'd give the floorpan a good looking over too, esp if you're heavy-footed.
I've toggled this thread a LONG time ago; have thrown it out here quite a bit since:
http://www.4x4wire.com/forums/showflat.p...&PHPSESSID=
Re: Clutch-4 rnr [Re: kewlynx] #978890 01/12/10 09:07 PM
AK Car Crusher, in Wasilla?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6340 MB (Peak: 0.7412 MB) Data Comp: Off Server Time: 2026-05-30 01:31:34 UTC
