Need help identifying an axle #978928 01/02/10 05:55 PM
hochkis Offline OP
There is a guy in town selling a montero axle that he claims is a genII (he said 92 or 93) Limited slip with 4.875 gears. The sticker on the rear end does say 4.875 and above that says T92. The rear pan is not removable and it only has one drain/fill plug. Is there anyway to confirm that this is an LSD without taking out the third member to look at it? I snapped a few pics with my phone if you need them. thanks for the help!
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: Need help identifying an axle [Re: hochkis] #978929 01/02/10 06:18 PM
should have a sticker saying LSD, otherwise rotate one axle and the other should turn the same direction.
Re: Need help identifying an axle [Re: TOASTY] #978930 01/02/10 06:24 PM
hochkis Offline OP
Well it's pulled from the truck and the truck is gone so i don't know about the sticker. They do both turn in the same direction but the pinion is spinning freely.
Re: Need help identifying an axle [Re: hochkis] #978931 01/02/10 08:38 PM
Then you have an LSD.
Re: Need help identifying an axle [Re: hochkis] #978932 01/03/10 04:29 AM
Is a 92-92 third the same as a 95 LS? Or, is your 95 4.875?
Re: Need help identifying an axle [Re: MontyMcV] #978933 01/03/10 09:47 PM
hochkis Offline OP
the thirds are the same on the outside, my LS is 4.636 but i plan to swap out the front end with a junkyard piece anyway.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6111 MB (Peak: 0.6807 MB) Data Comp: Off Server Time: 2026-06-23 06:12:58 UTC
