Page 1 of 14 1 2 3 … 13 14
The axle Swap and Build #978953 01/03/10 06:01 AM
Temple Offline OP
Well enough talk, here is the start of a whole lot of work and money,
I have finally started pulling the axles off and preping for the DANA 44 and Ford 9".
<img src="/forums/images/graemlins/shiner.gif" alt="" />
Oh its official I need a bigger garage!
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
Re: The axle Swap and Build [Re: Temple] #978954 01/03/10 06:21 AM
keep the mitsi rear
Re: The axle Swap and Build [Re: TOASTY] #978955 01/03/10 07:00 AM
Temple Offline OP
I'm going to use the ford 9" 1 for width 2 for the large aftermarket support.
I'm pretty sure the 9" is going to be better in the long run, its uses in Drag cars, hotrods, baja trucks. so there is tons of support for this axles and when i break it i'm just gonna toss in the chromoly's if i break it again you tell me ( I told you so)other then that i am confident with this axle.
But the 89swb is for sale minus gears and Limited Slip <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: The axle Swap and Build [Re: Temple] #978956 01/03/10 09:53 AM
LandRaider Offline
I like that "Pile O IFS" on the floor. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: The axle Swap and Build [Re: LandRaider] #978957 01/03/10 01:17 PM
Mad_Scientist Offline
Great project <img src="/forums/images/graemlins/kewl.gif" alt="" /> I agree with TOASTY, keep the mitsu rear. The Ford 9" may have good support if you break it, but I don't know anyone who has broken a Mitsu rear, esp a Gen 2 9.5".
Keep up the good work though <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: The axle Swap and Build [Re: Temple] #978958 01/03/10 03:01 PM
Dude I hate to be Sam Safetey. but cinder blocks? <img src="/forums/images/graemlins/shame.gif" alt="" /> At least if you must use them, can you turn them so they are on the load-bearing side? I have seen the effects of those being used on their side, not for a car but a bunch of heavy equipment and it was kind of funny seeing it sitting on the ground after I told the boss not to do it that way. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: The axle Swap and Build [Re: Mudraider] #978959 01/03/10 05:15 PM
Temple Offline OP
I foresaw some one giving me grief about the cinder blocks, i tried to use them on there load bearing side but my shortly cut safety 2x4's wouldnt have enough support to give me the illusion that they may continue to hold up the mighty raider.
Re: The axle Swap and Build [Re: Temple] #978960 01/06/10 11:07 PM
Temple Offline OP
I love it when new parts come in, I'm gonna start tearing into the raider next week if everything goes well.
Re: The axle Swap and Build [Re: Temple] #978961 01/07/10 12:08 AM
As to your safety 2x4s, the load is not supported on the 'span' section of the board, but only in the vertical dimension. That said, pick up some better jackstands...they are cheap compared to crushed 4x4wire members.
I am not the fourth to point his finger of non-guilt at one's self. My pink 60s block were essential in changing service bodies on my SoCal Dodge trucks: them and a hi-lift did wonders. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: The axle Swap and Build [Re: Temple] #978962 01/07/10 12:36 AM
ES_97Sport Offline
Nice! It'll be sweet when its done. Good luck!
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6467 MB (Peak: 0.7718 MB) Data Comp: Off Server Time: 2026-10-29 14:51:30 UTC
