Page 3 of 14 1 2 3 4 5 13 14
Re: The axle Swap and Build [Re: 0778drz110] #978973 01/11/10 04:24 AM
Oyaji_Jon Offline
Alright did some measuring, the new wheel base will be 10'-11.5'(ft).
so im hoping that will allow it to get some gnarly angles.
120-138" holy jebus! I was thinking about 105ish...
Yeah, I was thinking the same thing. Most competition buggies go for the "magic" 109, if I remember correctly, for good turning radius and breakover angle.
I will say that it'll be pretty difficult to go "a$$ over tea kettle" with your proposed set-up. <img src="/forums/images/graemlins/lol.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: The axle Swap and Build [Re: Oyaji_Jon] #978974 01/11/10 10:41 PM
Temple Offline OP
I might shorten down it all depends, i'm not shooting for rediculous but more for capiable and practical, i'd like to drive it to work every once an awhile and hurt some jeep guy feelings (or chevy; Ram; or ford) that but this box kit slap on chrome 20's put some fat low walled "off-road tires" and buy the everyday lift kit then cry if it gets dirty. not saying everyone but over in va. wheres theres not alot of offroad spots and we dont get snow, it might be a compensation.... sorry for the rant. But i cant waitfor it to get started (i'd say done but will it really every be done?) hopefully this week will start meassuring the mounts and location for the axles coilover brackets then the four link brackets.
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
Re: The axle Swap and Build [Re: Temple] #978975 01/15/10 12:20 AM
Temple Offline OP
What transfer cases can I use with the gen 1 automatic v6 raider? and do they all have slip yokes?
Also i know it was talked about awhile ago but I couldnt get any luck on the search i'm looking for the gear ratio for 1st gear and the gear ratio for 4low and the mathematical formula to figure out my crawl gearing i'm trying to figure out my axle gearing.
Thanks
Dean
p.s. start work on the raider monday so new pictures comeing soon!
Re: The axle Swap and Build [Re: Temple] #978976 01/15/10 01:37 AM
0778drz110 Offline
IMO jeep np231 crawlbox to a a fliped dana 300 twinstick from a jeep cj
np231-2.72:1,
d300 is around 2:1 (google it)
1st gear is around 3.5:1 I would guess
You'll want axle gears more than 5.xx for sure, like 5.38s
Re: The axle Swap and Build [Re: 0778drz110] #978977 01/15/10 04:13 PM
dannytuned Offline
The D300 is 2.62:1
That's the setup I run.
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: The axle Swap and Build [Re: dannytuned] #978978 01/15/10 11:42 PM
Temple Offline OP
whats the d300 and is it an easy bolt swap?
Re: The axle Swap and Build [Re: Temple] #978979 01/16/10 04:48 AM
0778drz110 Offline
d300 from an older jeep,twin sticks that control front and rear. example: front axle in forward/rear in neutral for tight turns and front digs
Re: The axle Swap and Build [Re: 0778drz110] #978980 01/20/10 10:03 PM
Temple Offline OP
Axle tube inserts with johnny joints, I love new parts!
Re: The axle Swap and Build [Re: 0778drz110] #978981 01/20/10 10:10 PM
Temple Offline OP
will the raider transmission output shaft fit into the d300, or are there a bunch of mods that I'll need to do?
Re: The axle Swap and Build [Re: Temple] #978982 02/01/10 05:27 AM
Temple Offline OP
Cutting out the fender wells getting ready to box in the rear this week!!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6483 MB (Peak: 0.7731 MB) Data Comp: Off Server Time: 2026-06-09 01:26:10 UTC
