Re: Raider Transmission Problems!!! [Re: 0778drz110] #979603 01/06/10 06:50 PM
Cmon now, DrZ, 4-5" of lift? I have 2" of bodylift and some 2" shackles with flat <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> springs and fit some 35's. If my springs bweren't so flat I dunno if I would of needed the shackles. I totally agree about not using OD though. I turned mine off for around town driving.
Re: Raider Transmission Problems!!! [Re: Mudraider] #979604 01/06/10 07:01 PM
0778drz110 Offline
2+2=4 <img src="/forums/images/graemlins/pfft.gif" alt="" />
I think the springs come nearly flat from the factory too...mine are the same way
Heck 2" lift fits 35s...with lots of trimming
OP:
2" bodylift(for ease of install) and a 1-1.5" torsion bar crank should be good. Thats if you don't feel like fixing the tranny of course...but think of it this way, you have 35s on it now <img src="/forums/images/graemlins/evil.gif" alt="" />
IMO i don't think the tranny is broken, something else...the auto aren't too commonly broken
Re: Raider Transmission Problems!!! [Re: 88raider4morgan] #979605 01/06/10 07:37 PM
Kevin C Offline
Is that a 1989-90 V6 Montero transmission? Will it work with the stock transfer case?
Yes and yes.
To be sure the OD won't work if the OD solenoid is not energized. The fastest way to check is verify power at the solenoid. I would also test the solenoid for continutity, the manual shows it has having 13 ohms resistance to ground.
The OD control system is the most common failure. A bad solenoid is easily changed. It's held on with two bolts and has two O rings under it. Trying another one is a low cost test.
Two other posibilities.
1: The Valve body.
2: The OD clutch has a bad seal or a bad clutches.
The valve body is easy to service in the vehicle. Most internal failures will be from bad seal that then kills the clutch pack. On the units I have rebuilt the OD always seemed to be in the best condition.
Kevin
Re: Raider Transmission Problems!!! [Re: Kevin C] #979606 01/06/10 07:51 PM
hazy_daze Offline
The valve body bolts were a little loose on mine when I serviced. Think Justice's were too. That could cause some harky malarky shifting...
Re: Raider Transmission Problems!!! [Re: hazy_daze] #979607 01/06/10 08:07 PM
Kevin C Offline
Good point on the valve body bolts. They were loose on my 87's as well.
Kevin
Re: Raider Transmission Problems!!! [Re: Kevin C] #979608 01/06/10 09:57 PM
0778drz110 Offline
MUDRAIDER
it says you don't accept private messages at this time
Your message box must be full...
carry on...
Re: Raider Transmission Problems!!! [Re: 0778drz110] #979609 01/07/10 03:00 AM
DrZ, somehow that got changed.Fixed now. On mine, the solenoid under the dash was the problem.
Re: Raider Transmission Problems!!! [Re: Kevin C] #979610 01/07/10 03:18 AM
Geophie Offline
Well does his 2.6/auto situation involve stuff like throttle position switch and a coolant temp sensor? I know these items can wreak havoc on auto trans shifting.
Just went through that (again after about 5 years) on my 91 v-6. After putting in a new idle control solenoid and readjusting the TPS....and then finding out I should've loosened the KICKDOWN cable FIRST before all that. Had to redo the TPS setting again without the kickdown cable connected to the belcrank and THEN reconnect the kickdown cable and adjust it to spec.
Apologies if this muddies the water. Please be nice. I have to fart.
1991 4dr RS, ATK 3.0, auto. Now with zero trans fats!
Re: Raider Transmission Problems!!! [Re: Geophie] #979611 01/07/10 03:23 AM
Temple Offline
FYI, I got 35's under my raider with a coil swap from a LWB and a torsion crank........... and then lots of creative fender cutting. <img src="/forums/images/graemlins/shiner.gif" alt="" />
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6354 MB (Peak: 0.7394 MB) Data Comp: Off Server Time: 2026-06-17 16:37:50 UTC
