Page 3 of 6 1 2 3 4 5 6
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: cmonty72] #979789 01/08/10 09:04 PM
off-roader Offline OP
So your going to bolt those on? I like the idea of them being gusseted onto a diamond shaped base and welded to the frame. Drilling lateral holes through the frame kind of fries my brain for some reason.
Any thoughts on benefits of either method?
Nope, I'm going to weld it, rather than bolt it to the frame, but the mount kit offers either option. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: off-roader] #979790 01/08/10 09:23 PM
Gotcha! those bracket are perfect bases... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: cmonty72] #979791 01/15/10 10:03 PM
RECON45 Offline
Are these things on yet. <img src="/forums/images/graemlins/smile.gif" alt="" /> When you do get them on can you test them with the hi lift jack? I want to make sure on what every slider I get that it can be used as a good jack point. O yeah I forgot where I read it but is the Gen 1 have the same length rockers as the Gen 2?
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: RECON45] #979792 01/15/10 10:16 PM
At work so not much time but answers below.
1) No.
2) Of course I will but the real test will be boulders. <img src="/forums/images/graemlins/evil.gif" alt="" />
2) Pretty close I assume but I never measured them. Just measure yours and check on Trail-Gears's site what size they sell will fit best.
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: RECON45] #979793 01/15/10 11:50 PM
Grasscat Offline
No.
Michael j
TreadLightly! Trainer
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: Grasscat] #979794 02/04/10 01:36 PM
Ummm, i just took a measuring tape out to my '95, and unless I'm mistaken, the skids you ordered are way too long...
Have you held them up to see if they fit? <EDIT> Question intended for off-roader...
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: off-roader] #979795 02/04/10 03:01 PM
Angelo Offline
The small triangle pieces they gave me, I didn't think they would be strong enough. I'll have to snap a pic and show you what mr and my friend came up with. Basically took a tube, same thickness as the leg, cut it in half long ways so it formed a triangle and then provided much more support throughout most of each leg. I also angled mine upwards cause of the body lift which provided more clearance in return. Post pics when you are done!
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: Angelo] #979796 02/04/10 03:14 PM
PHIL_ Offline
I angled mine upwards slightly, but they still sit horizontal enough to stand on. (The TrailGear sliders fit perfectly.)
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: Angelo] #979797 02/04/10 03:17 PM
Please do take a pic. I'm interested in making mine as strong as possible.
Please address the length question I posed as well. I'm ready to order!
Re: 96SR Rocker Panel Protection... AKA Sliders [Re: JohnnyBfromPeoria] #979798 02/04/10 05:12 PM
You're right but I have plans... <img src="/forums/images/graemlins/lol.gif" alt="" />
Actually the shorter ones are just a bit shorter than I'd like so I've bought these a little long on purpose. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6447 MB (Peak: 0.7548 MB) Data Comp: Off Server Time: 2026-06-22 16:08:17 UTC
