Page 2 of 3 1 2 3
Re: heard today...... [Re: jaboo5322] #979868 01/07/10 04:51 AM
6
69442 Offline
Yup cold shrinks. Just like swimmin in cold water. <img src="/forums/images/graemlins/smile.gif" alt="" />
Hate to think what would happen to it at -51 degrees <img src="/forums/images/graemlins/confused.gif" alt="" /> Don't think my manhood could handle that <img src="/forums/images/graemlins/lol.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: heard today...... [Re: 69442] #979869 01/07/10 04:56 AM
Hydra747 Offline
What Manhood?
Sorry, But had to! <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: heard today...... [Re: Hydra747] #979870 01/07/10 04:58 AM
6
69442 Offline
Don't blame ya, I stepped into that one <img src="/forums/images/graemlins/kewl.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: heard today...... [Re: 69442] #979871 01/07/10 05:37 AM
bombardj1 Offline
even Hydra's wife says what cold ? she's married to a Nurse so she knows her way around a tweezers <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: heard today...... [Re: bombardj1] #979872 01/07/10 05:41 AM
6
69442 Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: heard today...... [Re: kewlynx] #979873 01/07/10 05:46 AM
bombardj1 Offline
hey kewlynx
you still blaming the dog for the broken tire bead, shame shame shame, come on you know they still have the video tape of you , lol <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: heard today...... [Re: bombardj1] #979874 01/07/10 05:51 AM
Hydra747 Offline
hey kewlynx
Re: heard today...... [Re: bombardj1] #979875 01/07/10 09:12 AM
kewlynx Offline
Tell ya what, trying not to pee on yer carharrts is a bit of an art form. <img src="/forums/images/graemlins/shame.gif" alt="" />
Oh, and the fix for that flat is a weedburner and an air compressor. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Provided your propane hasn't liquified that is. <img src="/forums/images/graemlins/shiner.gif" alt="" />
**ubi apis- ibi salus**
Re: heard today...... [Re: kewlynx] #979876 01/07/10 11:07 AM
2002_Sporty Offline
Tires loose some air pressure in the cold weather naturaly. Cold shrinks. I think.
Cold Weather And Your Sportys Tires:
Your SportyÆs tires need to maintain the tire pressure listed in your ownerÆs manual.
If you have oversized tires, then look online for the manufacturerÆs specifications for that specific tireÆs cold pressure rating.
The tire pressure recommended in the manual is what is called a cold pressure. This does not mean that it is only for cold weather; but the temperature that your tires should have been before you starting to drive on them for the day.
Once you have driven on the tires they are warmed up. If you measure the pressure after driving, you will get an incorrect reading.
It is recommended that you check your tires weekly during winter months.
For every 10 degrees Fahrenheit change in the outside temperature, the tiresÆ air pressure will change by about 1 pound per square inch (psi). This measurement falls with colder temperatures and rises with higher temperatures. Adjust measurement according to temp.
Avoid deflating your tires in an effort to improve traction on ice or snow when driving on the highway or in the city. This method does not work. Severely deflated tires generate a lot of heat and may blow out, causing an accident. (Deflate only when 4x4ing off road).
Sporty lives out side in the cold. (No Garage).
Expect to have ôsquare tiresö after sitting overnight in severe cold climates. The warm air in your tires rises and the cold air and ground cools the bottom of the tire. So the tire goes ôflatö. This will resolve itself once you begin to drive and the air starts to circulate and warm itself.
This can be seen more often in bias tires than radials, but is not always the case.
Remember to drive slowly till the tires warm up to operating temperature. Driving in excessive speed with ôsquare tiresö can lead to ply and/or tread separation causing an accident, because of the tires heating up excessively.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: heard today...... [Re: 2002_Sporty] #979877 01/07/10 01:15 PM
2002_Sporty Offline
aluminum wheels get way cold they are more likely to lose the air seal and leak down
Air leaks from alloy wheels are not uncommon.
1. Porosity in the alloy casting is some times a factor in air leaks.
* If porosity in the casting were the issue then your Sporty would have seen air leaks from day one. Not only during the colder weather.
2. In most cases when an Alloy wheel leaks, it's caused by corrosion at the inside edge of the wheel rim where the bead of the tire is seated.
* The issue of corrosion at the bead tends to occur on the second, third or fourth set of tires mounted on the vehicle. As the corrosion builds up, it's more difficult for the bead of the next tire mounted on that rim to seal fully.
* Thoroughly cleaning the buildup of corrosion from the bead area on the rim is an important step whenever a tire is dismounted or mounted on an alloy rim. In addition, tire shops can apply a special sealer to the rim area to help seal the tire bead and prevent future air leaks.
Obviously when temperatures change so does the expanding and contracting of metal objects; like wheels.
So if you have corrosion then it could expand in the cold and cause a leak.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.345s Queries: 15 (0.281s) Memory: 0.6454 MB (Peak: 0.7581 MB) Data Comp: Off Server Time: 2026-10-21 17:14:09 UTC
