Tow truck winch rating. #980074 01/07/10 10:37 PM
89montero Offline OP
I've always been keeping an eye out for a winch and through a buddy found a guy parting out an old towtruck. The winch is an electric warn winch, seems fairly big but couldn't find a rating. AT first i figured was probably pretty weak as all it needed to do was lift the front of a small car off the ground, then I figured it's probably also used to pull vehicles out of ditches and such.
Any ideas on what a tow truck winch is rated at? It's the kind where the winch is mounted behind the cab and the cable runs over the boom.
Just a small pickup based rig kinda like this but don't think it was a dodge http://www.vehicle-liquidation.com/showroom/images/DODGE%20TOW%20TRUCK%201.jpg
1989 Montero 4dr V6 3.0l
Re: Tow truck winch rating. [Re: 89montero] #980075 01/07/10 11:15 PM
Brand? model #? with those you can probably google it...
Re: Tow truck winch rating. [Re: fasteddy] #980076 01/07/10 11:49 PM
Va_Stumpy Offline
If it was originally installed on a wrecker of that "vintage",it's probably substantial even if it needs rebuilding. That's around a '78 dodge.If it's like the older equipment I see around here, it will pick our rigs up to airborne as long as the battery holds up.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Tow truck winch rating. [Re: 89montero] #980077 01/07/10 11:53 PM
hazy_daze Offline
Snap a pic if possible.
Re: Tow truck winch rating. [Re: hazy_daze] #980078 01/08/10 12:26 AM
I'll try to go take another looks, didn't really look all that closley at the winch or the truck. It was an electric Warn winch, looks pretty substantial but i've never owned a winch so IDK.
I'm pretty sure it was a early/mid 80's chevy. that was just a pic i found online to show it's one of the pickup based "mom/pop towing" sorta deals.
Just wondering if tow truck winches are usually around 2k or 10k pounds.
Re: Tow truck winch rating. [Re: 89montero] #980079 01/08/10 03:34 AM
Va_Stumpy Offline
I've got a couple of buddies in the towing business(NO... they haven't repo-ed anything of mine!)I'll ask them as soon as I can.
Va_Stumpy
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Tow truck winch rating. [Re: Va_Stumpy] #980080 01/08/10 03:40 AM
1
1986powerram50 Offline
OT
I think being a tow truck driver would be so awesome. Before I die I hope to own a rollback or a full on tow truck.
--keRby
Ad Inexplorta
Re: Tow truck winch rating. [Re: 1986powerram50] #980081 01/08/10 04:57 AM
Tag Offline
The little bit of tow truck driving I have done was OK. Some times it got a little interesting. It was very fun picking up the 3 university cheerleaders. Fortunatly I never had to do highway recovery or accident recovery. A Rollback is the reason I purchased my Raider. The Raider was the only vehicle at the time that was able to drive up it without the winch.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Tow truck winch rating. [Re: Tag] #980082 01/08/10 08:33 AM
real common tow truck winch is the ramsey 8000 or 12000 worm drive they look like this [Linked Image]
You can tell a worm winch right away because they don't sit flat they bolt on the front and back usually into a cradle because of the worm gear on the bottom side. Worm drive winches are far more powerfull than regular planetary types, as in a 8000 worm is going to have more grunt than a 12000 planetary and can be used all day everyday. Worm winches are the king of winches for sure.
Re: Tow truck winch rating. [Re: 1986powerram50] #980083 01/08/10 01:32 PM
sparkem Offline
OT
It is not awesome.
PHP: 7.4.33 Page Time: 2.514s Queries: 16 (0.006s) Memory: 0.6407 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-11-14 15:48:31 UTC
