Re: Noisy front axle noise with the hubs locked [Re: Andy87] #980467 01/16/10 10:00 PM
MAC Offline
Thanks, I'm gonna give the plastic unit a shot.
Re: Noisy front axle noise with the hubs locked [Re: Andy87] #980468 01/18/10 08:23 PM
MAC Offline
Andy, Do you you have your PVC cap handy that you could measure the inside depth for me? My cap seems shallower and I don't want to make it up and find it don't fit.
Re: Noisy front axle noise with the hubs locked [Re: MAC] #980469 01/19/10 06:34 AM
A
Andy87 Offline
I don't have mine accessible right now, unfortunately. But, the caps should be a standard size. I think there are ASTM standards or something like that (UPC?) which dictate the diameter, depth, tolerances, etc. for fittings like that.
Regardless, the cap could have almost zero depth to it whatsoever and it would still work- you'd just have to push the axle through a bit farther, and find a thicker spacer to stick in back. And, if you use a shallower PVC cap then you'll end up wasting less grease as well.
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
Re: Noisy front axle noise with the hubs locked [Re: Andy87] #980470 01/27/10 11:33 PM
MAC Offline
my cap is schedule 80 as opposed to your schedule 40. 80 is heavier wall... but like you say, it looks plenty deep.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6068 MB (Peak: 0.6624 MB) Data Comp: Off Server Time: 2026-11-03 17:43:17 UTC
