No Heat BRRrrr #980944 01/14/10 03:42 AM
mike71800b Offline OP
Gen 1 3.0 v6. I pulled the lines at the firewall and with the temp slider to the warm side can pump water through the heater core so both it and the valve can flow, the supply line from the engine delivers coolant out of it when cranked briefly to check flow. I also squirted with the water hose into the lines going back into the engine. The supply line that goes into the heater valve would take water in and raise the radiator level. The return hose from the heater core back to the engine didn't take any flow or raise the radiator level that i could see. Thats a tight spot back there , i see one is flanged with two bolts and the other clamped to a pipe.
Can anyone enlighten me as to where these two are going? There isn't a hidden manual cut off valve i don't know about is there?
Thanks for replys
Mike
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: No Heat BRRrrr [Re: mike71800b] #980945 01/14/10 05:30 AM
Maybe corrosion blocking the return? No other valves besides the one on the core.
Re: No Heat BRRrrr [Re: rxinhed] #980946 01/14/10 08:54 AM
I'd run a small diameter coil spring down the blocked hose, or maybe a flat plumbing snake, or hit it with some air pressure. Is it possible you are deadheading against the thermostat? Try removing it and hitting the hose with hose water again. The FSM is spotty on which hose is which. The clamped hose should be a direct flow off the water pump. The flanged hose connection looks like it comes off the lower intake, but I can't remember the exact water routing. Been too long since I've been in there.
Any body got an upper intake off and could shoot some pics? I'm pretty sure the flanged connector is the return side, but not sure enough to make any definative comment.
Re: No Heat BRRrrr [Re: fasteddy] #980947 01/14/10 03:23 PM
mikes88troop Offline
is this what your looking for ?
Re: No Heat BRRrrr [Re: mikes88troop] #980948 01/14/10 07:26 PM
Thanks, but no. I need the lower intake that bolts to the head and has the t'stat on it on the front and may have the two bolt water flange on the back. Appreciate the try, though. Sorry I wasn't clear enough.
Re: No Heat BRRrrr [Re: fasteddy] #980949 01/14/10 07:31 PM
i got that too,here you go.
Re: No Heat BRRrrr [Re: mikes88troop] #980950 01/14/10 08:00 PM
Thank you, sir. Exactly right.
OK, the two flange connector goes straight into the heads thru the lower manifold, as I thought I remembered. The water pipe under the lower mani goes straight to the water pump, IIRC to the pressure side of the pump, but that may be wrongo. I doubt either path is blocked in the metal. This leaves a blocked hose, perhaps from an internal collapse. Replace the hoses.
Re: No Heat BRRrrr [Re: fasteddy] #980951 01/14/10 09:58 PM
Ok I found what looked like some radiator seal down in the clogged pipe. I've got a leak at the heater core and will start a new thread if i don't turn up anything in the search.
Thanks
Mike
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: No Heat BRRrrr [Re: mike71800b] #980952 01/26/10 06:11 AM
Well I got minimal heat at first and got back in there and dislodged of all things a friggin cork that had been jammed into the return line....
just goes to show you never know what a previous owner may have done .... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: No Heat BRRrrr [Re: mike71800b] #980953 01/26/10 09:28 AM
4ePikanini Offline
These pics might help as well. They are off a 1993 gen2 3.0 12v V6.
I presume it will be the same.
The red and blue goes to the rear matrix.
The red in the top and the red in the bottom pic is the same.
The long pipe on the intake plenum goes to the heater core's open pipe on the top picture.
Hope it helps
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6394 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-06-05 17:39:34 UTC
