Re: What Fit's - What Hit's... What Are You Rolling On?
[Re: Hydra747]
#981066
01/16/10 05:10 AM
I'll proly have a lift long before you have new sneakers <img src="/forums/images/graemlins/lol.gif" alt="" /> Polly true....but the Jury is still out on that one! <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> Jury .... we be'n judged on this crap
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting ..... ____o_o l_l_l\___\___ l----[o]==[o] l----==[--]== ()_)()_)--()_)
[Re: 69442]
#981067
01/16/10 12:04 PM
can i suggest a pic or two to go with the details so people can see what tthe rigs looks like with xx" size tyres and x" of lift i will be putting mine up as soon as i get it sorted out and on the road
[Re: flyinwall]
#981068
01/17/10 06:19 AM
Rokia 35 x 12.5 15 Ho lotta work to get these to fit.
Relocate rear axle 2" Install solid front axle 4" forward Approx 8"-10" of suspension lift 1 3/8 Body lift Trim rear bumper Toss front bumper & build new 1 1/5" wheel spacers 10" wide wheels with 2" negative offset
Dont run roof lights or a roof rack if ya park in the garage, I gotta fold them back to get it it there. <img src="/forums/images/graemlins/nana.gif" alt="" />
Why go around? When You can go over!
[Re: KIAFREEKROB]
#981069
01/17/10 10:27 PM
Relocate rear axle 2" Install solid front axle 4" forward Approx 8"-10" of suspension lift 1 3/8 Body lift Trim rear bumper Toss front bumper & build new 1 1/5" wheel spacers 10" wide wheels with 2" negative offset Nice!
Dont run roof lights or a roof rack if ya park in the garage, I gotta fold them back to get it it there. <img src="/forums/images/graemlins/nana.gif" alt="" /> So that's why I see the Humvees with their dammmm lights on rack bent back! <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />
[Re: Hydra747]
#981070
01/17/10 11:03 PM
Users Name: ScottC Wheel Size: 15x8 Cragar soft 8 Tire Size: 30x9.5 BFG All Terrain T/A KO Lift Size: 4" UPYOURKIA front TJ rear springs. Had to put .25" spacers on the front wheels because they didn't clear the calipers (not enough offset <img src="/forums/images/graemlins/shiner.gif" alt="" /> ). I have an EX with the fugly factory "body kit" so I had to do a little trimming on the front bumper cover and the "mudflap" part of the body trim so the front tires don't rub when turning. Nothing major though. ![[Linked Image]](http://i302.photobucket.com/albums/nn105/volvotech411/the%20KIA/th_IMG_1443.jpg)
Keepin It Awesome
[Re: ScottC]
#981071
01/21/10 01:15 PM
ScottC, I had to do a little trimming on the front bumper cover and the "mudflap" part of the body trim so the front tires don't rub when turning. Nothing major though. I see the trimming you did on the front bumper in your pics on another thread, but I don't see where you trimmed the front mudflap part of the body panel. I have those stupid body panels on my Sporty too. I'm interested in what you did. I have 15x8 Wheels with 2.5" of backspacing. I'm concerned about clearance. I don't know if they will turn in the wheelwell. Main concern is the front wheelwell mudflap.
2002 4dr Kia Sportage 4X4 Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
[Re: 2002_Sporty]
#981072
01/21/10 01:55 PM
Users Name: Dryver Wheel Size: 15 x 8ish" Centerline Rims - 3.75" backspacing (bought used with tires already on them) Tire Size: 31x10.5 Hercules Terra Trac AT (30.3" actual diameter) Lift Size: 3" UYK front, TJ 104AA springs rear
Had to pound the seam flat and trim both the inner and outer fender behind the front tires. Originally trimmed the bumper, then removed outer shell. Have some steel to fab a new bumper but haven't gotten around to it yet.
Rubs only when turning in reverse during normal driving. Probably should have gone with the 4" UYK. Might add a 1.4" body lift in the spring if I can get all of the rusted body mount bolts loose. (Dang Ohio salted roads...)
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD. GONE, all I have left are a few spare parts and the wheels.
[Re: ScottC]
#981073
01/23/10 02:02 AM
User name: Dennis Thompson
Wheel size: 15x7 American Racing Outlaw II
Tire size: 31x1050x15 BFG KOs
Lift: Front, 2 1/2" Eibach WITH 1 1/2" UPYOURKIA Spacers (4" total), Rear Stock TJs (4" total), + 1 3/8" body lift.
No rubbing any where, next tires will be 32x1050x15 TSL radials if the 33x1050x15 BFG KMs wont fit. I also have a Smittybuilt XRC8 Winch with no front end sag.
Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
[Re: 2002_Sporty]
#981074
01/25/10 05:15 AM
ScottC, I had to do a little trimming on the front bumper cover and the "mudflap" part of the body trim so the front tires don't rub when turning. Nothing major though. I see the trimming you did on the front bumper in your pics on another thread, but I don't see where you trimmed the front mudflap part of the body panel. I have those stupid body panels on my Sporty too. I'm interested in what you did. I have 15x8 Wheels with 2.5" of backspacing. I'm concerned about clearance. I don't know if they will turn in the wheelwell. Main concern is the front wheelwell mudflap. I left the outer part you can see just so it didn't look all hacked up. I started about an inch inward along the bottom edge and cut up and angled it over as I went up, giving it just enough room for the tire to clear it when turning the wheels. I'll try to get a picture for you.
Keepin It Awesome
[Re: Hydra747]
#981075
01/28/10 01:04 PM
Users Name: Sportage Wheel Size: Stock 15 X 6.5 Tire Size: 235/75 Wrangler M/Ts Lift Size: 40mm (1 1/2")
Rubs on the rear right shock, but did from stock when new.
Dare to be different
'01 Long body, 40mm lift, AVM manual hubs, snorkel.
