Page 3 of 4 1 2 3 4
Re: QUICK brakes question? [Re: DamKia] #981173 01/19/10 09:52 PM
Hydra747 Offline OP
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Rear Breaks also needed to be re-adjusted as someone said earlier! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Prolly did not need the master cylinder changed but oh well...... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: QUICK brakes question? [Re: DamKia] #981174 01/19/10 10:26 PM
6
69442 Offline
Emergency braking technique for Hydra747 <img src="/forums/images/graemlins/lol.gif" alt="" />
May I suggest a stronger more sturdy fence for better braking results <img src="/forums/images/graemlins/lol.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: QUICK brakes question? [Re: 69442] #981175 01/19/10 11:49 PM
bombardj1 Offline
wan'a stop on a dime, measure the center of the bumper to the center of the tire, then measure the outter bumper to the middle of the axle, now find a phone pole, measure the center of the phone pole out to the side make the ground and place a dime on the ground. get back about a 100yards and floor it make sure the pole is lined up with the center of bumper, hit the pole dead-on, (well you might be dead on alright) the impact should be enough for the front end to be pushed in far enough so the tire comes to rest right on top of the dime.
how bout it mikeyboy
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: QUICK brakes question? [Re: bombardj1] #981176 01/20/10 12:16 AM
Hydra747 Offline OP
Shall I start a poll on it???
Forget it You Jackass!
HAHAHA
<img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: QUICK brakes question? [Re: Hydra747] #981177 01/20/10 10:51 AM
2002_Sporty Offline
Hope your brake issue gets fixed man. Here's my story.
It's like -30 below freezing outside on friday and my rear drum brake freezes up solid. Or so I think. So I take the other truck to work. Sunday I take it down to the father-in-laws shop. On the way there (about 13 miles) I am avoiding all traffic stops and/or attempting to hit every light. Cause every time I hit the brakes that rear drum locks up and I'm down the road sidways for a mile till the damn thing breaks loose. I get down to the shop thanking God for the arrival without a rear tire blowout. There happens to be anywhere from two to four inches of ice on all in town roads so that helped also. I take the wheel off and realize that I can't get the rear passenger drum off without a special puller tool. WTF!!! So I decide to take a space heater to the drum brake to see if that helps it break loose. After about five minutes under heat the rear drum breaks loose and I have been driving on it ever since. I don't know what the issue is? Ice/condensation build up in the drum? Loose, damaged or broken shoe? Bearings in axle frozen? I'm stumped. This issue happened last winter everytime it got below -30 degrees outside or if I take it into a garage to warm up then back outside. The weather has been above -20 most of the weekend, so I don't know if It'll happen again. I did bleed that rear drum when I was at the shop. Took off the bleeder valve and nothing came out. I pumped the brake and some fluid squirted out. I think I may have condensation build up or something in that damn drum? I'm taking it down next week after I get paid to have the rear drum pads replaced.
Oh, I lifted the rear end up and checked the axle for LSD? None! Damn it!!! Good luck with your brakes man.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: QUICK brakes question? [Re: 2002_Sporty] #981178 01/20/10 07:12 PM
bombardj1 Offline
with the rear drums, if they have been on for a while there is most likely a lip at the edge of the drum and the shoes are up inside the lip just enough so that the drums will not slide off without backing off the adjuster star, you can slide hammer all day long.
Re: QUICK brakes question? [Re: bombardj1] #981179 01/21/10 05:26 AM
Sportege_Panicmech Offline
Well, if our drums are not self-adjusting, then they shouldn't be too hard to take off even with a lip on them. but usually I find that hammering on the face of the drum as hard as I can without hitting the studs helps to break things loose. Under extreme cold conditions you can get ice buildup. I hear it's best to park in gear rather than w/ e-brake in lower temps. May want to look into the operational range of grease and brake fluid. wonder when that stuff freezes. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: QUICK brakes question? [Re: bombardj1] #981180 01/21/10 06:56 AM
blitz Offline
absolutely true !, theres a slot with a rubber insert under axle. have to adjust brakes down to clear that lip. i pounded, pulled,heated ,cussed, then figured it out...ITS THE LIP! steering wheel puller popped it right off after that.
Re: QUICK brakes question? [Re: Sportege_Panicmech] #981181 01/21/10 07:10 AM
jaboo5322 Offline
What's engine timing like in -30, half a day before top dead center? <img src="/forums/images/graemlins/notooth.gif" alt="" />
Would be if i lived there. <img src="/forums/images/graemlins/scared.gif" alt="" />
No timing light, use sundial. <img src="/forums/images/graemlins/lol.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: QUICK brakes question? [Re: jaboo5322] #981182 01/21/10 09:33 AM
2002_Sporty Offline
Thanks for the heads up on that F---ing drum. I never had rear drums on any vehicles that I owned. At least I never had to service them. I wanted to beat the Sh!+ out of that drum, but I refraned from causing any more damage. Wish I knew of the adjuster and the screw removal method before hand. Now that I know, I'll prepare for my second attempt.
Jaboo - Sun dial? There has to be sun to use one of those things man! <img src="/forums/images/graemlins/lol.gif" alt="" /> The whole top of the world is tilting away from the sun during this time of the year! Global warming would be nice about now. It's -18 degrees Below zero right now. I just had my timing chain, belt and water pump replaced last summer. So I can only assume that your dead on accurate with the timing estimate.
I don't intend on stealing the thread from Hydra, thanks for the advice though. Good luck on those brakes man.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6450 MB (Peak: 0.7563 MB) Data Comp: Off Server Time: 2026-10-22 07:38:46 UTC
