Page 3 of 4 1 2 3 4
Re: Winch w stock bumper [Re: LandRaider] #981378 02/09/10 03:28 PM
Looking SWEET Kris and I do like that bumper! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Winch w stock bumper [Re: LandRaider] #981379 02/09/10 05:09 PM
G
Guns_and_Roses Offline
I think I'd have done a lil better job on the cutout for the shifter though.
I made a mistake thinking the clutch turned to the left. i am going to cut it more square and put a plastic cover over it later.
Re: Winch w stock bumper [Re: Guns_and_Roses] #981380 02/09/10 10:00 PM
Angelo Offline
first off, TJM is very rare to even find on a vehicle. Second, you found one at a junk yard. Third, you got it for $50!! You were extremely lucky! Sweet find for sure! Glad to see you aren't wasting any time. Is that the new "Marn" winch? <img src="/forums/images/graemlins/lol.gif" alt="" />
Looking good over there. Btw, what did it come off of?
Re: Winch w stock bumper [Re: Grasscat] #981381 02/09/10 11:14 PM
scottiesharpe Offline
Nice job! Very nice!
Scottie Sharpe
Sunny San Jose CA
Webmaser for BMW TURBOS! Forum
http://bmwturbos.scottiesharpe.com
1995 Montero SR
Re: Winch w stock bumper [Re: 89montero] #981382 02/10/10 12:43 AM
lordtrunks Offline
your worm will mount different that every winch shown above because of the gears it uses rails on the front and back. I'll get some pics posted up but i have mine behind the stock bumper well kinda of i cut the steel yesterday i just need to weld it in. I have also cut off the sway bar mounts so i can get the winch back far enough.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Winch w stock bumper [Re: Angelo] #981383 02/10/10 05:01 AM
G
it came off of a 1992 toyota 4runner just like this one.
Re: Winch w stock bumper [Re: lordtrunks] #981384 02/10/10 11:24 PM
lordtrunks Offline
ok here are a couple pics of winch and bracket rails I have to get them welded in still
I'm gonna remove this fairlead and remount it but make sure the gears hang down like in this photo that way they oil correctly.
Here is a over view i left the rail off so you could see where it bolts to on the winch(see the 4 loose bolts on winch)
Re: Winch w stock bumper [Re: lordtrunks] #981385 02/11/10 12:31 AM
89montero Offline OP
thanks, yeah mine's pretty much exactly the same as yours but I think I have the wider drum. I'll have to check. When I first measured it looked like it might be like 1/4-1/2" too big to fit between the frame. I haven't had time to mess with it but I think I'll be able to figure it out, maybe it can hang lower to the gearbox/motor are below the frame rail.
I was planning on cutting out something like what your doing and then just welding that to the frame.
1989 Montero 4dr V6 3.0l
Re: Winch w stock bumper [Re: lordtrunks] #981386 02/11/10 07:32 AM
LandRaider Offline
What did that winch come from?
Re: Winch w stock bumper [Re: LandRaider] #981387 02/11/10 07:33 AM
G
i was thinking P.G and E or some other utility type of vehicle.?
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6434 MB (Peak: 0.7533 MB) Data Comp: Off Server Time: 2026-05-29 17:54:23 UTC
