Twitchy Ignition, not the starter? #982360 01/24/10 02:11 AM
RockDoc Offline OP
Gentlemen: So I had a starter motor replaced on my Gen1 1990 Montero two months ago by a reputable mechanic. Since then, the ignition often does not turn over the starter motor when I try to start the truck. Turn the key and nada, zero. It has however, always turned over after 3-4 tries. After looking at the underside of the starter motor, it seemed like the wire from the ignition was poorly connected to the starter - a loose spade fitting. I relaced the fitting, it's plenty tight enough now to always make contact. Anybody got any ideas where I should go from here? Could this be a faulty starter, or a problem with the ignition in the steering column? Problem started AFTER I had the new starter installed.
Thanks! RockDoc
1990 SWB Montero, 3.0l auto, ARB lockers, OME suspension, 32' BFG AT's, PIAA light upgrade.
Re: Twitchy Ignition, not the starter? [Re: RockDoc] #982361 01/24/10 02:49 AM
motero Offline
Search for info on the inhibitor switch. Also know as the neutral safety switch. Clean that thing and go from there.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Twitchy Ignition, not the starter? [Re: motero] #982362 01/24/10 02:52 AM
8
89IsMine Offline
Clean your battery posts and cable really good -- especially if the dash indicator lights are weak and/or the voltmeter isn't registering properly.
Eric W.
Re: Twitchy Ignition, not the starter? [Re: 89IsMine] #982363 01/24/10 02:59 AM
MBrannon Offline
This is a very common issue with Mitsus. Here is a fix from the 3000GT site:
http://www.3si.org/forum/f1/100-guaranteed-click-click-start-fix-part-2-a-241359/
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Twitchy Ignition, not the starter? [Re: RockDoc] #982364 01/24/10 06:25 AM
hazy_daze Offline
If you're positive that this issue started after the starter was replaced, then logic says you got a less than 100% unit. After it clicks and doesn't spin the first time, crawl under and tap on the starter with a hammer while a helper turns and holds the key in the start position for about a 5 count. Do not strike very hard as gear reduction starters don't like the magnet being beaten up. If it turns over after a tap or two, then replace the starter.
Also, it's a good idea to replace the electrical portion of the ignition switch, especially if it's never been done and the part is original. It's a prime culprit for voltage drops which lead to sluggish starts and other weird issues. It's relatively inexpensive and an aftermarket part will work fine.
Re: Twitchy Ignition, not the starter? [Re: motero] #982365 01/24/10 10:39 PM
Motero had the same thing on mine. Cleaned it up and tada, works everytime.
Re: Twitchy Ignition, not the starter? [Re: RockDoc] #982366 01/25/10 12:26 AM
SandRaider Offline
I had the same issue on my raider after replacing the starter. It was a loose spade connector on the starter, replaced it and it hasn't happened again.
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: Twitchy Ignition, not the starter? [Re: SandRaider] #982367 01/25/10 02:41 AM
K_Raider Offline
Ditto... On mine the voltage checked out fine at the tip with a voltage meter but I guess some of the wires had come disconnected.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
PHP: 7.4.33 Page Time: 3.362s Queries: 15 (0.004s) Memory: 0.6256 MB (Peak: 0.7245 MB) Data Comp: Off Server Time: 2026-06-11 18:13:25 UTC
