Re: OverDrive Problem [Re: Kevin C] #982581 01/27/10 12:13 AM
87monty Offline OP
Sweet I will try it. Thanks Ill have a update.
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: OverDrive Problem [Re: 87monty] #982582 01/27/10 06:45 PM
87monty Offline OP
Ok so I tried hooking up the small one wire connector to ground and still nothing. Is this wire just yellow or does it have a stripe of another color? I looked around and only found two single wires one went to the temp gauge and the other one I said above that I grounded. <img src="/forums/images/graemlins/confused.gif" alt="" />
I looked through the fsm and I could not find the wires or where they go.
Wireing really sux...
96 SR
Re: OverDrive Problem [Re: 87monty] #982583 01/27/10 11:28 PM
87monty Offline OP
Ok so i found the right wire and grounded it. With the key on I push the O/D on and off and can here a clicking sound down by the tranny. so on the way back to work i still have no over drive. So could it be the solenoid or the relay?
96 SR
Re: OverDrive Problem [Re: 87monty] #982584 01/30/10 01:09 AM
87monty Offline OP
Im going to pull the solenoid out tonight and take a look.
is there a way to test the relay?
At this point I cant go on the freeway without O/D
kinda bummed <img src="/forums/images/graemlins/frown.gif" alt="" />
96 SR
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6062 MB (Peak: 0.6629 MB) Data Comp: Off Server Time: 2026-06-24 13:48:44 UTC
