Re: How to get that extra inch...
[Re: FOURSKIA]
#983011
02/28/10 04:27 AM
Just in case you are wondering, why I didn't get the suspension shop to make the spacers... it would cost me more then if they make a set of springs... some BS of having to make a templet that they wouldn't prob use again as very little market for sporty's here in Aus. <img src="/forums/images/graemlins/angry.gif" alt="" />
Sportage, 75mm lift, 30"s A/T,UHF& HF, AVM hubs and more to come.
[Re: FOURSKIA]
#983012
02/28/10 09:03 AM
Kia Moderator
I got a spacer/adapter spare for the front struts if you want?
Weighs about less then 1 lb .....So calculate and PM me if interested.
Also give me the shipping rate...Don't feel like getting raped by the Ausi regs.. <img src="/forums/images/graemlins/shame.gif" alt="" />
It is for 3" front though.... Thanks Hydra, but my Kia can only handle an approx 1.5 inch... 3inch is way too much for her. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> But I'll keep that in mind if I can't find anything else, might be an option if I put back the original spring. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Be careful of what you ask for, you just might get it... To give a 3" lift you only need a block of about 1.5" high due to the geometry of the suspension, a 2" lift needs a 1" block. The "saddle" acts on a point halfway along the length of the lower arm, multiplying the net effect of lifting x 2 (leverage effect).
[Re: FOURSKIA]
#983013
03/03/10 12:13 PM
Cool ... your way ahead of me <img src="/forums/images/graemlins/angry.gif" alt="" /> Well just another update a few more questions for you guys. I'm waiting on some spacers from Everet but as I know these custom made items take time... and unfortunately I'm running out of time (I start my new job in another state at the end of next month) and I have already paid for the rear springs and shocks to be fitted. If Everet is unable to get the spacers to me soon I will have to ask the suspension shop to make me some front springs aswell so i don't lose my money (these things are made to order so no refunds <img src="/forums/images/graemlins/barf.gif" alt="" /> ). I'm worried if I do need to get the longer front springs ( i think I'll only end up with approx 1 inch of movement/articulation) the suspension shop doesn't recommend this... <img src="/forums/images/graemlins/scared.gif" alt="" /> has anyone fitted longer springs to the original front strut or the same size KYB? If so any probs? Secondly, once I get thsi shorted I'm looking to get some body spacers fitted in Melb... I see that Roger Brown (I think) sells these...anybody know if they fit on a longbody sporty? If so...how easy are they to install, i read the instrct and it says that you should replace the nuts on the rear then do the front...but wouldn't that bend the thread/bolts or worse break it as you lift the front? <img src="/forums/images/graemlins/confused.gif" alt="" /> This guy http://www.4wheelnoffroad.com/04body.html didn't replace any of the nuts as he went along...I would og thought this to be the best way as to not break or bend the threads/bolts. Anyway any feedback would be appreciated. HI Fourskia, I senty an inquiry in early FEB to them regarding the body lift as I wanted to get a two inch as it is the max legal without running into major probs in AUS. (No airbag in mine <img src="/forums/images/graemlins/nana.gif" alt="" />) Due to the bolt design they only make either the 1 3/8 I think the size is and the 3 inch lift. If you have airbags have fun getting it engineered without lots of research. Damkia is running a two inch in his but I believe he had the captive bolts removed from the body and inserted new ones? His is a big bum as well. Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
[Re: 4runnernomore]
#983014
03/10/10 07:02 AM
O.K. got the lift in... <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> I also have some pics to share. So to sum it up, the best way to get an extra inch in Aus is with bigger springs and shocks... but their is a problem.
[Re: FOURSKIA]
#983015
03/10/10 07:18 AM
The problem as documented before by Richard (2002 Sporty) when he broke a shock is plain to see in the photos below. <img src="/forums/images/graemlins/barf.gif" alt="" /> Really would like to fix this before I test it out on my next hunting/4wdriving trip, anybody know if a panhard rod extension will do the trick? (I know that wheel spacers would work, but illegal here in Aus... <img src="/forums/images/graemlins/shame.gif" alt="" />) As you can see with only half of the possible articulation it really pushes against the shock. <img src="/forums/images/graemlins/angry.gif" alt="" />
[Re: FOURSKIA]
#983016
03/10/10 07:30 AM
O.K. for anybody who is interested... These shocks have given the kia just over 3inchs of lift, the ride isn't as good as the King spring set up that I had that almost felt like I was driving a car and it gave 1.3inch lift but the ride is still alot better (and safer) then the original spring set up, prob a bit of a harder ride then I was used too but still comfortable on the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />.
I havent had a chance nor do I want to test it offroad untill I resolve the rubbing problem (makes sense I guess, get an extra inch and you might end up with rubbing problems... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> ) but except for that I'm sure it will perform very well.
Thanks 4runnernomore for the info... <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: FOURSKIA]
#983017
03/11/10 06:01 AM
Kia Moderator
Only solution is new rims. I have the F100 4WD rims that only have about 4" from the WMS to the inside of the rim (known as backspace), versus about 5 1/4" in the stock rims. Depending on your eventual choice of tyres you may need to do some bodywork, as the extra tyre sticking out of the wheelarch can hit the wheelarch.
[Re: DamKia]
#983018
03/11/10 03:27 PM
There is one other solution, provided you're allowed to do it over there. You could do a shock relocation like the kit Dave was offering.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD. GONE, all I have left are a few spare parts and the wheels.
[Re: Dryver]
#983019
03/11/10 05:31 PM
are u talking the upper part (being the dust shield of the shock)i took a grinder and cut that off and put on a rubber one problem solved <img src="/forums/images/graemlins/cheers.gif" alt="" />
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
[Re: jays2001]
#983020
03/11/10 09:45 PM
are u talking the upper part (being the dust shield of the shock)i took a grinder and cut that off and put on a rubber one problem solved <img src="/forums/images/graemlins/cheers.gif" alt="" /> Have any pix??
