Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR [Re: monster_max] #983059 01/30/10 06:26 AM
StockRaider Offline
If your that worried about the crank having terminal damage. I would pull the engine, remove the crank, and replace it if necessary. Far cheaper than a swap.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR [Re: StockRaider] #983060 01/31/10 01:57 PM
MBrannon Offline
Yeah, pull the crank out and have it repaired or replaced. Throw in some new bearings and a oil pump and your good for another 200k. You can even do that with the motor in the truck if you want.
Or sell it and move on. I think those are your best choices.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR [Re: MBrannon] #983061 01/31/10 04:03 PM
Can you get the crank out from underneath? Pistons then too for putting new rings on?
Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR [Re: MontyMcV] #983062 01/31/10 11:55 PM
StockRaider Offline
it can be done, but its really easier to just remove the engine and do it on a stand.
Richard E
1983 Honda XL600R
Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR [Re: StockRaider] #983063 02/01/10 01:59 AM
MBrannon Offline
You can get the crank out but not the pistons. Pistons have to come out from the top. I've never seen a piston ring issue on these motors though.
If you have a shop and resources, I'd pull the motor. If you are doing this in a driveway then I would leave it in.
1998 Montero
2007 Prius
Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR [Re: MBrannon] #983064 02/01/10 04:54 AM
[Pardon the hijack, MM...]
When I put the new heads on, the compression was still soft and the spread on the high side. Since then (two months now), I have had to add oil at times. Two quarts now with one just last week, and it could use a little more to top it off.
When the heads were off, the cylinder walls looked great. I could still see the cross-hatches fine. All that, at a 165k miles.
If I have to pull it, can't help but want to find an SR donor and do a swap. Too bd I couldn't swing the one a few months ago from a guy who wanted $500 for one that was not running and had the top half of the engine in the back.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6182 MB (Peak: 0.6878 MB) Data Comp: Off Server Time: 2026-06-23 18:44:59 UTC
