Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR
[Re: monster_max]
#983059
01/30/10 06:26 AM
If your that worried about the crank having terminal damage. I would pull the engine, remove the crank, and replace it if necessary. Far cheaper than a swap.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#983060
01/31/10 01:57 PM
Yeah, pull the crank out and have it repaired or replaced. Throw in some new bearings and a oil pump and your good for another 200k. You can even do that with the motor in the truck if you want.
Or sell it and move on. I think those are your best choices.
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: MBrannon]
#983061
01/31/10 04:03 PM
Can you get the crank out from underneath? Pistons then too for putting new rings on?
[Re: MontyMcV]
#983062
01/31/10 11:55 PM
it can be done, but its really easier to just remove the engine and do it on a stand.
[Re: StockRaider]
#983063
02/01/10 01:59 AM
You can get the crank out but not the pistons. Pistons have to come out from the top. I've never seen a piston ring issue on these motors though.
If you have a shop and resources, I'd pull the motor. If you are doing this in a driveway then I would leave it in.
[Re: MBrannon]
#983064
02/01/10 04:54 AM
[Pardon the hijack, MM...]
When I put the new heads on, the compression was still soft and the spread on the high side. Since then (two months now), I have had to add oil at times. Two quarts now with one just last week, and it could use a little more to top it off.
When the heads were off, the cylinder walls looked great. I could still see the cross-hatches fine. All that, at a 165k miles.
If I have to pull it, can't help but want to find an SR donor and do a swap. Too bd I couldn't swing the one a few months ago from a guy who wanted $500 for one that was not running and had the top half of the engine in the back.
