Re: Longer UCA bolts for Gen1 [Re: MarcDurant] #983581 02/11/10 11:58 PM
FrankR Offline
I'm seeing anywhere from $3-$8/each, but having trouble finding the finer thread bolts (12x1.25 or even 12x1.50). I found an old post from FrankR saying that he bought a box of them, I was hoping he'd have some left.
I just read this post - hold on........ here's what I have - they're Grade 10.9, 2 3/8" (60mm) long w/nylock nuts and split washers.
Is that what you need? If so, I'll be glad to sell them for whatever you'd like to pay. Just PM your address.
Frank
Re: Longer UCA bolts for Gen1 [Re: FrankR] #983582 02/12/10 12:30 AM
MarcDurant Offline OP
Excellent! How much longer are these bolts than Gen1 stock? I'm at nearly 1.5 degrees of camber right now, which is... 90 minutes, times 1mm/13' = I need at least 7mm longer than stock. Right?
I'll definitely take a set off of your hands. They should fit nicely into the small size USPS prepaid shipping box, so shipping should be $4.90. How about $20 for a set of four bolts, shipped?
89 Raider V6 manual
89 Montero 2-door Coupe "Super Legera"
91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
Re: Longer UCA bolts for Gen1 [Re: MarcDurant] #983583 02/12/10 01:05 AM
FrankR Offline
That's more than fair - just make sure it's what you need.
The factory parts list shows the OE bolt to be M12x50mm. I'm not sure that's correct because I threw my old ones away. Here are pictures of my Gen1 with the 60mm bolts installed with 3 shims and there's still more than 1/4" left for more shims:
Frank
Re: Longer UCA bolts for Gen1 [Re: FrankR] #983584 02/12/10 04:50 AM
Oyaji_Jon Offline
I'll take the other set off your hands, Frank, if'n they'll work.
Thanks.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Longer UCA bolts for Gen1 [Re: Oyaji_Jon] #983585 02/12/10 05:10 AM
FrankR Offline
OK, but I think $20 is too much - $15 for each of you sounds good to me.
PM your addresses if you think they'll work for you.
Frank
Re: Longer UCA bolts for Gen1 [Re: FrankR] #983586 02/12/10 07:44 AM
Oyaji_Jon Offline
Sounds good, Frank. I don't know if they'll work, but you can't have enough big bolts lying around, can you? PM inbound...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Longer UCA bolts for Gen1 [Re: Oyaji_Jon] #983587 02/12/10 08:28 AM
LandRaider Offline
My truck used to have some parts that looked like that. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Longer UCA bolts for Gen1 [Re: LandRaider] #983588 02/12/10 10:29 AM
Oyaji_Jon Offline
Well, if this land deal I'm trying to get going goes through, I'll be building my own 'lil chop shop on 2 acres in the hills. :fingerscrossed:
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6319 MB (Peak: 0.7305 MB) Data Comp: Off Server Time: 2026-06-18 13:08:48 UTC
