Re: Check out these off-road tires. [Re: NathanC] #984541 02/09/10 03:00 PM
FrankR Offline
Thanks, Nathan. That's a nice product. I wish the price was justifiable, but it isn't for our wear history. I'm getting about a year from a tire that's around $300 installed and adding in a couple of flat repairs per tire, the payback takes too long for today's financial rationalization.
Frank
Re: Check out these off-road tires. [Re: FrankR] #984542 02/11/10 12:33 AM
NathanC Offline
I'm fairly certain you can re-cap a skid steer tire.
Sounds like you do a lot of running light if you are wearing out the rears.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Check out these off-road tires. [Re: NathanC] #984543 02/11/10 12:45 AM
FrankR Offline
Not really - but we usually run with only 1/3 of the rated load capacity on gravel and those are the steer tires. We do a lot of tight-quarter jockeying and some folks don't understand that the rear should be steered as little as possible.
Frank
Re: Check out these off-road tires. [Re: FrankR] #984544 02/11/10 01:17 AM
Grasscat Offline
Frank
But Frank I'm confused.
Most Skid Steers uses all wheels to steer, side to side like a tank. AT least our Bobcats do.
Bobcat make a machine called a articulated loader is that what you have?
Michael j
TreadLightly! Trainer
Re: Check out these off-road tires. [Re: Grasscat] #984545 02/11/10 01:49 AM
FrankR Offline
No, I'm running one 10k lb rated CAT DP45K with solid tires for light duty:
One 10k lb rated MasterCraft rough terrain C-10 with pneumatic tires for medium duty:
And one 16k lb rated 4x4 MasterCraft rough terrain C-16 with pneumatic tires for heavy duty:
The pictures are not our equipment - but they are similar to ours. Ours are just newer versions - 18 months old.
The 2 MasterCraft rough terrain machines use skid steer rear tires. The C-16 4x4 is a hoss. <img src="/forums/images/graemlins/kewl.gif" alt="" />
One of our yards does have a CAT IT-28 articulated loader, but we have forks on it instead of a bucket - here's a picture of a similar one with a bucket:
Frank
Re: Check out these off-road tires. [Re: FrankR] #984546 02/11/10 08:31 PM
Grasscat Offline
OK Frank, that make sense now as the Bobcat would be to small for your work load.
Michael j
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6195 MB (Peak: 0.7058 MB) Data Comp: Off Server Time: 2026-06-07 05:00:44 UTC
