Page 1 of 4 1 2 3 4
Has anyone put the 4.70 gear in their single transfer case pickups? #984666 02/08/10 08:29 AM
Ralph Offline OP
I have been thinking about 2 transfer cases for awhile.
A couple places I hunt are pretty rough. In first/Low range I have to ride the clutch just to slow the pickup down.
Dual "T" cases would be sweet but an over kill, and costly.
If could simply install the 4:70 it should cut my ground speed in half in First/Low range.
With my 22REC would I need the 23 spline setup?
It does run pretty strong for a 4 banger.
So what do you guys think?
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984667 02/08/10 03:37 PM
trcdrunner Offline
You can run em.... you'll need 2nd more....
Friend had the 4.7's in a single set up, he liked - but to cruise a trail you'll be in the higher gears (3rd & 4th)
- on a side note, which could be that you're EFI, I can practically crawl my rig in 1st & Low and brake on a decent with out clutching.. letting the engine help hold her back and braking (no clutching)...
Thats a 22r 33"s and 4.30 gears.....
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984668 02/09/10 12:28 AM
4Crawler Offline
Can be done, basically you'll have gears 1-5 in low range, then shift to high range and have gears 1-5, with no overlap in gearing. You'll only be able to do about 15-20 in low range.
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: 4Crawler] #984669 02/09/10 02:28 AM
Ralph Offline OP
I am doubling the torque. Will I need the 23 spline setup?
Is one brand any better than the next?
Ralph
Home Made Cat Backs
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984670 02/09/10 03:37 AM
4Crawler Offline
I think the only way you could run the 23 spline single case is to have a turbo (R151F) transmission. But the trans-tcase shaft will not see any more torque than stock, that is limited by what the engine*trans_ratio can put out. You could put in a HD output shaft like Marlin carries.
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: 4Crawler] #984671 02/09/10 02:52 PM
Staceman Offline
Your truck currently requires 21 spline.
I have a single 4.7 case. Difference offroad is bar none. Obstacles at near idle, rather than working the clutch. The only downfall is cruising around in 4-Lo. Max speed in 5th gear, is approx 15 MPH with your engine getting up in the RPM range. On a side bonus, with what you will save in the future on clutch replacements should offset the gears' cost. After 25K miles with 4.7's offroad, my clutch / flywheel / pressure plate surfaces all look like brand new parts. Unlike my old blistered, blued nasty components removed before the 4.7 upgrade.
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Staceman] #984672 02/09/10 11:11 PM
ErikB Offline
Toyota Moderator
It doesn't sound like you need something a TON lower than what you've got now. I'd probably recommend 4.0's instead of 4.7's so that your only low range choice isn't quite SO low and is a little more usable all around. If you did a lot of rock crawling, then it might be another story.
Of course duals are the ultimate in all around gear choices <img src="/forums/images/graemlins/mrt.gif" alt="" />, but as you know, its a much more substantial modification.
And not that you have a choice, but 21 spline will be plenty for a 4cyl and single case. You would have to try REALLY hard to break anything in the t-case. The upgrades aren't really needed until you double up the torque in duals or put it behind a lot more motor.
http://home.4x4wire.com/erik
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: ErikB] #984673 02/09/10 11:44 PM
Ralph Offline OP
"I'd probably recommend 4.0's instead of 4.7's ..."
Who makes the 4.0's? I've done a lot of research and don't remember seeing one.
Ralph
Home Made Cat Backs
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984674 02/09/10 11:54 PM
Staceman Offline
Great call Erik, I think 4.0 would be in his best interest.
These guys have 4.0 gears...
http://www.northwestoffroad.com/parts/diff_transfer.html
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984675 02/10/10 06:48 AM
toyrunner Offline
I put the 4.7 set into my 85 4Runner and really enjoyed the difference that it made.
I would just go into 4Hi when wanting to do faster easy stuff and drop into 4Lo when wanting to crawl through stuff.
I say go 4.7 and don't look back. I am getting a Tcase setup next week for my stock 85. It won't be so stock anymore. I also won't be cooking clutch on the trail as said above! <img src="/forums/images/graemlins/smile.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 1.637s Queries: 16 (0.004s) Memory: 0.6470 MB (Peak: 0.7685 MB) Data Comp: Off Server Time: 2026-05-27 15:42:37 UTC
