Page 4 of 4 1 2 3 4
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984696 02/24/10 03:08 AM
4Crawler Offline
Yes, or you can simply redrill your own flanges:
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: 4Crawler] #984697 02/24/10 03:20 AM
Ralph Offline OP
It looks like I could take a front drive line and have it re-sized "Lengthened" to use as a rear drive line.
Any hints or tips on this subject?
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984698 02/24/10 04:25 AM
RatLabGuy Offline
Personally I LOVE my auto transmission and 5.29 gears, standard case.
I can go any speed I want, crawl or fast. Yeah it won't win a 1/4 mi race, but who cares.
People rag on the a/t but IMO, being able to crawl along and not have to do the 3-legged dance makes it totally worth it.
Question Reality.
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984699 02/24/10 05:09 AM
4Crawler Offline
See if you have a local drive line shop, take the shaft there with the length you measure flange to flange and they can re-tube it to the length you need. Have them use a heavier wall tubing while you are at it, will hold up to rocks better. Or send it off to High Angle Driveline and they can fix it up for you.
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: 4Crawler] #984700 02/26/10 08:24 PM
Ralph Offline OP
Is there a thread that covers the installation and setup of dual transfer cases?
Ralph
Home Made Cat Backs
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984701 03/01/10 03:31 PM
4Crawler Offline
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: 4Crawler] #984702 03/02/10 12:02 AM
Ralph Offline OP
Thanks for the link.
What I had in mind was a things to do list after the dual T-cases were installer with tips and hints.
Such as .... maintaining drive line angles.
Rotate rear end shorten rear drive line and install a CV Joint. Will I need a speedometer extension?
Something to follow along with. Something that maps out first things first and a parts list.
I'm sure someone has already done this before.
Ralph
Home Made Cat Backs
Re: Has anyone put the 4.70 gear in their single transfer case pickups? [Re: Ralph] #984703 03/02/10 12:05 AM
4Crawler Offline
Sort of takes care of itself, you are just moving the front/rear flanges back.
http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
Usually yes, unless you have about 6.5" slack in your current cable and you have a mechanical speedo. If electrical, see if the wires are long enough.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6360 MB (Peak: 0.7352 MB) Data Comp: Off Server Time: 2026-06-07 04:59:14 UTC
