Tranny differences
#985417
02/14/10 04:36 AM
Was wondering if anyone knows if there is any difference between 4wd and 2wd Auto tranny EXCEPT for the rear part of the case? Can you swap the rear parts and make a 2wd a 4wd or a 4wd a 2wd? Is the output shaft the same length? Gearing? Shift points? Looking to do some modifications.
Any help would be appreciated.
Everet <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Tranny differences
[Re: Everet]
#985418
02/14/10 05:04 PM
Kia Moderator Emeritus
As far as I know (and can determine), they are identical.
The FSM does not mention this combination (auto w/2WD) even though it was an available drivetrain. It does mention 5 speed stick w/2WD.
You should be able to easily find a Sportage in California with this drivetrain and crawl underneath and take a look. I know this combination was very popular in Florida when I was there about 8 years ago. I call them "Mall runners" because they ain't much good for anything other than that. <img src="/forums/images/graemlins/shiner.gif" alt="" />
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Everet]
#985419
02/14/10 06:14 PM
the gasket for the rear of trannies to the hoising assy-ext of the 2wd and the adaptor that go to the T/C are the same gasket so that means same mounting, the drive shaft I beleave is 2pc on the 2wd with a u-joint in the middle, the 4wd is not,
So if you have a 2wd tranny and wanted to put it in a 4wd from the bellhousing to the rear of the tranny minus the cone would fit a 4wd but would need a rear cone to the T/C and a different driveshaft, same goes for a 4wd to a 2wd a different driveshaft, remove T/C and different cone, but would need the center support for the 2wd driveshaft, one thing if going to a 2wd from 4wd make sure the center support bracket is welded to the frame on the truck, to know what I mean you would need to look under both a 2wd and a 4wd to look at the center support.
hope this helps, John
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#985420
02/14/10 08:44 PM
The Tail shaft on the 4x2 auto is TOO LONG!
Unless you are very knowledgeable and gutting and replacing then it can be done......
They are both indeed different.
[Re: Everet]
#985421
02/14/10 08:52 PM
Was wondering... EXCEPT for the rear part of the case? Reading is fundamental! <img src="/forums/images/graemlins/lol.gif" alt="" /> Yes, they are both identical.......except for what you said above Everet! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: MY 4x2 to 4x4 Conversion
[Re: bombardj1]
#985422
02/14/10 10:14 PM
make sure the center support bracket is welded to the frame on the truck, Hey John, Do you mean this??? ![[Linked Image]](http://i110.photobucket.com/albums/n114/hydra747/Picture10004.jpg) If it is what I think your getting at....Then Don't need one on the 4x4.....Shorter D-shaft and no carrier bearing.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Hydra747]
#985423
02/15/10 01:44 AM
no mikey the center support for the driveshaft there is a donut type bushing that is held in place about midway from the rear of tranny to the rear diff. I don't know it if is there on all the frames or not or just the 2wd, because of the longer driveshaft, thats right that you don't need it if it is a 4wd, but if going to 2wd w/out T/C you need it
Re: tranny
[Re: bombardj1]
#985424
02/15/10 02:37 AM
Thanks John, Then what is the part???????
Re: tranny
[Re: Hydra747]
#985425
02/15/10 01:49 PM
don't know . would have to be under your rig to see side by side, could be a frame support, why did u get it cut out anyway ?
Re: tranny
[Re: bombardj1]
#985426
02/15/10 03:00 PM
look under yours....Do u have a 4x2...still...Don't you?
Thanks John <img src="/forums/images/graemlins/kewl.gif" alt="" />
