Re: Pics : My Sport Cage
[Re: dannytuned]
#985634
02/16/10 12:10 PM
Looks nice. The cage is tucked in quite well. Have you considered running the third hoop to the wheelhouse rather than direct to the floor? It will take frontal hits at the top of the windshield better that way.
[Re: OldColt]
#985635
02/16/10 12:12 PM
Awesome! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: OldColt]
#985636
02/17/10 01:38 AM
Thanks guys Have you considered running the third hoop to the wheelhouse rather than direct to the floor? It will take frontal hits at the top of the windshield better that way.
This is why I put in the two rear down tubes, because the c-hoop is on that rearward tilt, they were an add-on not in my original plan. I like the way they look though. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
[Re: dannytuned]
#985637
02/17/10 01:44 AM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
[Re: NathanC]
#985638
02/17/10 03:20 AM
Totally awesome, Keep up the progress! What made you decide on chopping it? Everything going back in? Would be cool if you could get the rear hatch to open & close once it's done
[Re: Angelo]
#985639
02/18/10 12:00 AM
Totally awesome, Keep up the progress! What made you decide on chopping it? Everything going back in? Would be cool if you could get the rear hatch to open & close once it's done Thanks. I guess the main reason for chopping it, is that I have lots of time to spend in my garage. Being a Chicago union electrician, jobs are few and far between. I was starting the cage and thought it would be a cool, free, side project. <img src="/forums/images/graemlins/lol.gif" alt="" /> Sticking with factory seats and seatbelts. The dash might go back in, unless I can find some cheap sheet aluminum. The carpet and headliner are history. The rear hatch is already cut in half, the window part still flips open, but the lower part will be the tailgate. Under the rear window will be a slide out center section so I can flip open the window(remotely hopefully), slide out the center, put the back seat down, and back my dirtbike in. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
[Re: dannytuned]
#985640
02/18/10 01:26 AM
So I guess the gear oil smell from Haspin Acres is gone now. That is a big part of the reason I pulled my carpet out.
Are you bending the tubes or having a friend with a machine do it?
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Tag]
#985641
02/18/10 02:48 AM
Yeah the blast of gear oil smell in the face every time I open the door is not so nice. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Last year I bought a Pro-Tools 105 with a 1.75 die and Bend-Tech Pro(computer software). That software makes tube bending a breeze. <img src="/forums/images/graemlins/baby.gif" alt="" />
[Re: dannytuned]
#985642
02/22/10 01:25 AM
Some progress today. The main parts are squared and tacked, except for the windshield cross tube, I think I'm gonna raise it. Then I could drop the whole assembly, to weld the tops. Made these for the tie in to the engine compartment tubework. Have 6 more of the bushings for the frame connections. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: dannytuned]
#985643
02/22/10 01:59 AM
Looks great. I cant wait to see it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors 89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels 99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
