Re: Pics : My Sport Cage
[Re: dannytuned]
#985644
02/22/10 03:58 AM
<img src="/forums/images/graemlins/shiner.gif" alt="" />All right Danny I feel like an idiot asking but how did you drop it down? <img src="/forums/images/graemlins/confused.gif" alt="" />Is the roll cage going thru the body to the frame? <img src="/forums/images/graemlins/confused.gif" alt="" /> And you just lifted the body. I've spent way too much time looking at your pics to have not figured it out <img src="/forums/images/graemlins/rolleyes.gif" alt="" />, so clue me in please. Thanks.
[Re: Mudraider]
#985645
02/23/10 12:33 AM
<img src="/forums/images/graemlins/shiner.gif" alt="" />All right Danny I feel like an idiot asking but how did you drop it down? <img src="/forums/images/graemlins/confused.gif" alt="" />Is the roll cage going thru the body to the frame? <img src="/forums/images/graemlins/confused.gif" alt="" /> And you just lifted the body. I've spent way too much time looking at your pics to have not figured it out <img src="/forums/images/graemlins/rolleyes.gif" alt="" />, so clue me in please. Thanks. Here's a pic that should shed some light on things. If you look at the original pics there's about 12" of straight tube at the lower part of each hoop leg, for the purpose of being able to lower the entire cage, after tacked, to weld tops. I'll have to weld in the ceiling triangulation also, while the cage is lowered and tops are accessible. Hope it makes more sense now. <img src="/forums/images/graemlins/cheers.gif" alt="" />
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
[Re: dannytuned]
#985646
02/23/10 01:42 AM
Looks like you changed your front Radius arms. I thought they were from a ford truck.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Tag]
#985647
02/24/10 12:40 AM
Looks like you changed your front Radius arms. I thought they were from a ford truck. Same ones, they are 2" DOM welded to the wedge part of the Ford arm.
[Re: dannytuned]
#985648
02/24/10 04:59 AM
<img src="/forums/images/graemlins/shiner.gif" alt="" />All right Danny I feel like an idiot asking but how did you drop it down? <img src="/forums/images/graemlins/confused.gif" alt="" />Is the roll cage going thru the body to the frame? <img src="/forums/images/graemlins/confused.gif" alt="" /> And you just lifted the body. I've spent way too much time looking at your pics to have not figured it out <img src="/forums/images/graemlins/rolleyes.gif" alt="" />, so clue me in please. Thanks. Here's a pic that should shed some light on things. If you look at the original pics there's about 12" of straight tube at the lower part of each hoop leg, for the purpose of being able to lower the entire cage, after tacked, to weld tops. I'll have to weld in the ceiling triangulation also, while the cage is lowered and tops are accessible. Hope it makes more sense now. <img src="/forums/images/graemlins/cheers.gif" alt="" /> So your saying those tubes that are extended downward aren't for dropped running boards? <img src="/forums/images/graemlins/scared.gif" alt="" /> Just kidding, nice work!
[Re: dannytuned]
#985649
02/24/10 09:18 PM
That's what I figuref when I look at it. Just wasn't sure how it worked.
[Re: Mudraider]
#985650
05/07/10 10:02 PM
Finally got some work done on the cage. Rock sliders that tie into the cage mounts, and body mounts. Dash tube installed with the two tubes that go through the firewall to tie into the underhood part of the cage. ![[Linked Image]](http://i128.photobucket.com/albums/p166/sthsdr/pic174.jpg)
[Re: dannytuned]
#985651
05/07/10 10:33 PM
Where are you gonna put the hydraulic pumps so you can jump it?
Seriously, that is sick nice, except I'd put in a diagonal bar somewhere to triangulate one of the loops.
[Re: fasteddy]
#985652
05/07/10 10:55 PM
Yeah, there will be more triangulation to come, on the b-hoop and the dash area, too. I'm also thinking about running a tube from the floor to the roof bend of the a-pillar.
[Re: dannytuned]
#985653
05/14/10 02:05 PM
So where are you getting the laser cut sheet parts? Looks great!
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
