Page 2 of 3 1 2 3
Re: Changing upper ball joints [Re: Hydra747] #986287 02/21/10 04:33 AM
bombardj1 Offline
ease of motion same in all moving parts, same engine and brain over heat it to much both will fry. heat stroke engine and brain same again. a lot cheaper to replace a joint in a car then a joint in leg lol
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Changing upper ball joints [Re: bombardj1] #986288 02/21/10 04:43 AM
Hydra747 Offline OP
Thanks Mr. Miagi,
Danielson,
"Paint Small circle" (from karate Kid)! <img src="/forums/images/graemlins/confused.gif" alt="" />
I know I'm slow but what the heck do you mean John???
Thanks again,
Mikey <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Changing upper ball joints [Re: Hydra747] #986289 02/21/10 05:47 AM
jays2001 Offline
it goes by if u were sitting in the drivers seat <img src="/forums/images/graemlins/kewl.gif" alt="" />
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: Changing upper ball joints [Re: Hydra747] #986290 02/21/10 06:37 AM
bombardj1 Offline
everything has to fit right to work right, just as in humans and cars or anything else, cars are no different,. that why I wrote ease on motion, you can't over lift something or bind joints beyond it's limit
do you have all the other parts for the front, if you just started I would check out full kits on ebay, all the ties joints arms etc, so your not working on all this mix and match stuff.
Re: Changing upper ball joints [Re: Hydra747] #986291 02/21/10 06:53 PM
6
69442 Offline
In Nursing it is Anatomical ....With Motor vehicles I have no clue...? Anybody???
Thanks
Mikey <img src="/forums/images/graemlins/kewl.gif" alt="" />
Drivers - Left ... Passenger - Right
Headlamps - Front ... Taillamps - Rear
Roof - Top ... Floor - Bottom
<img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Changing upper ball joints [Re: 69442] #986292 02/22/10 03:16 AM
Hydra747 Offline OP
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/sleeping.gif" alt="" />
Re: Changing upper ball joints [Re: Everet] #986293 03/07/10 12:52 AM
Hydra747 Offline OP
Best price I've found so far is $49 each (+ SHIPPING) at <a href="www.rockauto.com" target="_blank">ROCKAUTO</a>
Thanks Everet,
I just bought a pair!
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Changing upper ball joints [Re: Hydra747] #986294 03/07/10 07:34 AM
I did both my Upper Control Arms last summer. Had a heck of a time as the rear spindle on both sides were seized to the sleeve. There was no amount of anything that I could have done with what I had. So I had to grind them out and replace with new.
The control arms cost $115.00 each
The Spindles cost $18.00 each.
I do have the Part Numbers on both Spindles if you need. But I am sure yours may come off.
Good Luck on yours smile
Re: Changing upper ball joints #986295 03/07/10 07:36 PM
jays2001 Offline
where did u get the price for the spindles that ur talking about and spindle are u talking the the bushing and the alignment bolt if so the price i have found here is 30 bucks a pop and i need four to do both sides and the ball joints got them 78 off ebay for both uppers that is <img src="/forums/images/graemlins/kewl.gif" alt="" />
our dealer in town is a f---ing rip off and the only place i have found them
Re: Changing upper ball joints [Re: jays2001] #986296 03/08/10 02:13 AM
The 2 spindles (or bolts)I got are apparently dealer items only, or an auto wrecker. I don't know about your area but around here I found only one place with 2 Sportages, and they are a 45 minute drive. But I would want to go new for these.
the front alignment bolts were in good shape still so I just reused them.
The bushings are connected to the control arm.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6380 MB (Peak: 0.7480 MB) Data Comp: Off Server Time: 2026-07-15 09:02:29 UTC
