Page 3 of 3 1 2 3
Re: Changing upper ball joints #986297 03/08/10 08:09 PM
Hydra747 Offline OP
I did both my Upper Control Arms last summer. Had a heck of a time as the rear spindle on both sides were seized to the sleeve. There was no amount of anything that I could have done with what I had. So I had to grind them out and replace with new.
The control arms cost $115.00 each
The Spindles cost $18.00 each.
I do have the Part Numbers on both Spindles if you need. But I am sure yours may come off.
Good Luck on yours smile
Wow,
The hail mary came through....Good info for my job to be.....I am sure that mine will come off though and I bought a new driverside hub assy due to noise probs (don't have time to see if it is needle bearing,seal etc....) <img src="/forums/images/graemlins/sleeping.gif" alt="" />
How do you post the text in the pics???????
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Mikey <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Changing upper ball joints [Re: jays2001] #986298 03/08/10 11:33 PM
bombardj1 Offline
the bolts are about $6 each so don't know whats talked about, did not know u could get the welded on spindle brakets and align them ?
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Changing upper ball joints [Re: bombardj1] #986299 03/09/10 05:06 PM
jays2001 Offline
i believe the rubber bushing is whats being talked about or at least thats what i am and yea bolt is the cheap side of this problem the dang rubber has a metal sleeve that runs through it and seizes to the bolts making alignment a b---- or impossible.
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: Changing upper ball joints [Re: jays2001] #986300 03/11/10 01:29 AM
bombardj1 Offline
upper bushings # is 0K01134830A about $19 each wholsesale.
Re: Changing upper ball joints [Re: Hydra747] #986301 03/11/10 03:12 AM
lol....post text in pix...well I loaded it up in Corel Photo Paint and did all that right on the photo.
I didn't know that you could get the bushings, ball joint and control arm as separate pieces. From what I heard when getting them for mine it was an all in one unit, and that's how they come. I don't think I would want to mess around with buying it all in pieces and putting it all together to install. Seems like way more work than needs to be.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6123 MB (Peak: 0.6776 MB) Data Comp: Off Server Time: 2026-07-15 18:36:30 UTC
